roberta berks
About roberta berks
    Fl east coast
    2000 Boxster,2006 cayenne titanium edition
    2001 911 turbo
roberta berks's Achievements
  1. Cayenne cranks fast no start anybody know of any dealer alternative shop that's not overpriced in the Southeast Fl region?
  2. Sure...I should mention this fast crank no start problem has happened before.But I let the car sit an hour came back and starts up and runs great no knocks pings backfires etc..which is why I'm leaning towards electrical?Any thoughts are appreciated..(i have no leaking water issues in foot well and have checked the wiring down there both sides)
  3. Sure thanks.I thought that too.Read Pelican Parts website explaining car needs to be warmed up first for proper readings...But I still am leaning towards a gremlin electrical connector.Ive had plenty of them on this car.Would PSM warning light on before this ultimately shut down the vehicle for dealer mode?
  4. I cant get the engine warm to get a proper test if it will not start? Also it sure sounds like a fast spinning no compression engine but the question is what electrical components/modules not working properly would create this fast spin?
  5. Yes I did replace some electronic modules already that were corroded from the humidity here.Which is why Im leaning towards something electrical again that may cause this non communication to start car with the fast crank.I don't see how a strong motor with 45k miles can all of a sudden have a valve issue or something more mechanical.Something electric not connecting all the dots and shutting something down?
  6. Thanks.The key sticks and cranks without me holding the key which Ive never seen before.The car has only 45k miles.Ran strong before this.Now fast crank without start.I don't have special testers,what do you suggest I start with that makes sense?Would an alarm or kessy module problem relate to this fast no compression crank?
  7. Will not start.Cranks faster than usual and key sticks in ignition cranking without touching it after turning key and then letting go of key.Car sits for months at a time on a battery tender.Ran fine before this issue.Pulled fuel pump fuse to start the secondary pump first, still same issue.Any help here would be appreciated greatly!
  8. Sure.May look at Kessy connectors for corrosion since its easier to look at first. No air suspension in this car.Appreciate the help !
  9. Right.Since the car has only 45k miles and runs great when it does run without symptoms or faults,I'm leaning towards some little connector that's corroded from sitting in humid Florida.It was that when I swapped out the rear convenience module a few months ago after gremlins started appearing and fixed without a dura or piwis.Maybe alarm module since it sits on top of rear convenience,I dont know.Real PITA vehicle.
  10. Sure, thank you.It does not show symptoms of hesitation or start for a second then die out that usually relates to fuel problem.(when running). Just intermediate fast crank like the key is not recognized (tried both keys). Some electrical gremlin again perhaps?That is all Ive had with this car.Car does sit for months at a time.Any other thoughts are appreciated!
  11. Sure, thank you.It does not show symptoms of hesitation or start for a second then die out that usually relates to fuel problem.(when running). Just intermediate fast crank like the key is not recognized (tried both keys). Some electrical gremlin again perhaps?That is all Ive had with this car.Car does sit for months at a time.Any other thoughts are appreciated!
  12. Thanks.Runs great when it starts.No fault codes.
  13. What would cause low compression on a 45k mile Cayenne that ran great?
  14. Have a problem once and a while when car sits for a month or so.I come back to it a couple times and sometimes it finally it starts.New battery and new key battery's. No second trunk battery.Seems like it cranks faster too.Key programming?
  15. Trying to erase some codes (brake pads,ABS, and ! )that Ive fixed..whats a cheap scan tool to erase them please?
