Horace Tyndall
Everything posted by Horace Tyndall
  1. It happened 😳🥺Now what do I do except take it to a shop. Reamed out the hex head on the sensor bolt. Sure I had the bit in firm but it wouldn’t budge.
  2. What size hex bit do I need for the bolt on the crankshaft sensor?
  3. Does it matter which end you disconnect or connect first?
  4. I found the cps after removing the oxygen sensor. My problem is where does the electrical connector connect to and where is it. Thanks
  5. Thanks Loren just what I needed.
  6. I am installing a Kenwood radio on my 2004 Boxster S and need a 12v switched supply. Where’s the easiest place to get this from?
  7. Hi Loren, I have a 2000 Boxster lost the radio codes. Not sure if this is the right place to post but I’ll try. Becker1 cdr 220 model 4462 serial # X5029317 Thanks for any help
  8. CD220
    4462
    ser# X5029317
    Becker1
    2000 Boxster 986
    need radio code
