wtsnt
    Marion, MA USA
    Cayenne S
wtsnt's Achievements
  1. I have a 2008 Cayenne S with the factory PCM. The date displayed is currently "02/03/2003"., see picture I checked the manual for how to reset the month, day and year, and evidently if you have factory navigation, you can't adjust this. The manual notes that the PCM gets the month, day and year from the GPS signal. The PCM diagnostic shows that I have a solid GPS signal. The car navigation system works without a problem. However, the month, day and year won't properly update. Has anyone else had this problem or does anyone know how to fix this/ It isn't critical, just highly annoying. In a somewhat unrelated 2 questions: 1. The PCM screen appears to have been coated in "something" at one time, about 80% of which is no longer there. Is there anyway of getting that remaining coating off the screen? 2. A lot of the dash parts were coated with a black rubberized coating, which like everything else, is peeling off. You can see it in the attached picture to the left of the passenger seat heater control. Short of removing all the dash pieces and peeling off the remaining black gunk, is there anyway to refresh or renew this short of buying new trim pieces? Thanks,
  2. When I opened the door on my 2008 Cayenne S yesterday morning I noticed that front wing rocker panel molding looked loose. When I looked at it more closely I discovered that it was completely disconnected on the lower side and that was because the rocker panel itself was completely rusted away. Does anyone know how to take these plastic rocker panel molding off so I can get a better look at the actual rocker panels below? Thanks, Terry Watson
  3. I had my 2008 Cayenne S in the shop for front wheel bearing replacement. The shop told me that my steering rack was leaking and noted that a replacement rack was about $2400. I looked through some Cayenne forums and have noted that there appear to be a number of companies that rebuild racks in the $500-$600 range. Has anyone replaced a steering rack with a rebuilt unit? Also, how do you tell if your Cayenne has Servotronic steering or not? Thanks, Terry Watson
  4. I am getting what i am pretty convinced is a failing front wheel bearing "whine" from my 2008 Cayenne S. Does anyone know the ballpark replacement charges for replacing both front wheel bearings? I have a great independent Porsche shop nearby and I will probably get them to do the work. Looks like *** bearings on Pelican Parts are about $92 each. Thanks, Terry Watson
  5. I have a 2008 Cayenne S. Recently when starting I have turned the key and only had the engine turn over a couple of times, then stop. If I turn the key off then try starting again, the engine fires up. Is this a symptom of a failing battery? I bought the car about 6 months ago so i don't know how old the battery is. I have seen that the battery is under the drivers seat? If this is a symptom of a failing battery, are there any recommendations on a replacement battery? Thanks, Terry Watson
  6. Does anyone have a recommendation for how to add Bluetooth connectivity to a 2008 Cayenne S with the stock head unit? Thanks,
  7. Thanks, the Pelican DIY article worked perfectly.
  8. I need to replace the seat switch assembly on My 2008 Cayenne S. I checked the DIY section and there doesn't seem to be a write up on this. Does anyone know how to get the plastic covers off the bottom of the passenger seat so I can access the switch assembly? Thanks, Terry WAtson
  9. Thanks, ordered a new strut that should be here on Saturday.
  10. The foot operated parking brake on my 2008 Cayenne S doesn't release completely when I pull the release lever. I have to reach down and manually pull the parking brake pedal upwards to get the parking brake to release completely. I looked at the diagram of the parking brake and it appears there is a small gas strut on the pedal. Does anyone know if that is what is supposed to retract the pedal when the parking brake release lever is pulled? If not, does anyone know how to fix this issue to get the parking brake pedal to release completely? Thanks, Terry Watson
  11. I recently purchased a 2008 Cayenne S. The drivers side front seat is missing the lumbar support "cover" on the lumbar adjuster switch. The passenger side front seat is missing the the lumbar support "cover" on the lumbar adjuster switch and the fore/aft / up/down cover on the switch that controls seat motion. I looked online for these part numbers and could not find them, so I went to the dealer to get these parts. Much to my surprise, the dealer said that Porsche doesn't sell these parts individually, you have to purchase the entire seat switch assembly for approx. $475 each. Does anyone know how to get a hold of just these switch actuator covers? I would think they must exist in the used parts world, does anyone have a source for used Porsche interior parts like these? Thanks, Terry Watson
  12. I recently purchased a 2008 Cayenne S with ~94k miles. Does anyone know the general torque range for DIY type repairs. My torque wrench has died and I am going to get a new one but didn't want to get something that didn't cover the most common torque settings for this car. Thanks, Terry Watson
