sebring boxster
About sebring boxster
  • Birthday 10/13/1957
Contact Methods
  • Website URL
    http://
  • ICQ
    sebring florida
    99 carrera jaguar xj8 2000 1992 corvette convertible 1994 f150 lightning 1998 dodge ram 2500 cummins 1995 range rover classic lwb 04 cayenne s
1,171 profile views
sebring boxster's Achievements
  1. Hi Loren is the expansion valve near the cabin filrer on the passenger side under glove box?
  2. thank you. what is the most simple way to see it
  3. Hi if you can could you tell me location of th expansion valve. I did find some oil residue in the smaller pipe that goes in the firewall i was able to give half a turn to the bolt. I pull vacum to 29 in 10 minutes and it held. I will check the o rings you suggested as soon as i could find the valve. Thanks a bunch.
  4. Hi could you tell me the location of the expansion valve?
  5. we could smell the freon inside i am afraid is going to be it My mechanic suggested a two formula sealer maybe that will work. i have nothing to loooooose
  6. First Thank you very much. I have a leak in the evaporator inside the car it takes about 2 weeks to leak the freon
  7. Hi does anyone know the part number for the evaporator core for 2004 cayenne s. also is the vw toureg the same part? do you if the cayenne has one or two evaporators. also location of the instructions or diagram on how to change the evaporator thank you.
  8. Hissing sound from the part blue smoke on start up makes terrible noise on start up missfires codes reads intake leak none found
  9. Thanks how do you change it and what is the part number
  10. can any one tell me the location of the oil separator for 2004 cayenne v8 s
  11. Thanks a friend suggested the oil separator do you know a quick test. He suggested taking the oil cap and checking for suction I did and it suck my palm very strong like a vacum cleaner This is a Cayenne not a 9x6 series car. this a cayenne s if you look a v8 turbo diagram for 2007 the parts shows in the diagram as oil separator
  12. Thanks a friend suggested the oil separator do you know a quick test. He suggested taking the oil cap and checking for suction I did and it suck my palm very strong like a vacum cleaner
  13. Thank you in my town no porsche tech have to travel about 80 miles for a dealer
  14. Hi Loren i check the fuses and also for broken hoses nothing could the oil separator be the problem does the v8 ave a aos do you know the location you are correct the first code will set of the others
  15. Ignore the diagram above then - it was for a V6 Cayenne. That part is still the crankcase bleeding but I am not finding it in the parts system. Perhaps you should email or call the folks at Sunset Imports. Hi Loren question can that part be cover under emission warranty? Maybe, you need to ask your dealer/OPC. Hi Loren now i am getting codes 1182,0507,0021,2187,2189 can you guide me on what to check the first one pcv do you know the location?
