drmindbender
Everything posted by drmindbender
  1. I have a 2001 that cranks with no start. So far I've: Pulled a coil and used a new spark plug touching the block and got spark Used scan tool to see the immobilizer signal turn on/off with key Tested the pump relay Checked voltage at relay pump power while turning key to start, shows 10v steadily dropping to 4v over 5 seconds Checked voltage at fuse (fuse is good) and get similar voltage Disconnected crank sensor and got P code for sensor and saw rpm not moving, reconnected and no code/rpm bounce to 300 Next step to pull battery and use test leads to power pump at connector? Is the voltage I'm getting at the relay/fuse correct? I've heard the pump only gets power for a second when cranking then only gets more power when the engine fires? How do I get the fuel out if the pump is actually dead? Thanks in advance, David
