P2C4
P2C4 last won the day on July 29 2023
P2C4 had the most liked content!
About P2C4
  • Birthday 06/22/1960
  • Interests
    skiing, hiking, tropical beaches, vinyl records, audio equipment and home theater systems
    Draper, Utah
    2009 Cayenne - great vehicle that runs and runs without costing much; purchased certified.
    2012 Cayenne Turbo - black on black, panoramic roof, Burmester sound. Dealer serviced before I bought it in 2020.
  • Future cars
    Will probably buy a 2009 or newer C4S and a 2012 or newer Panamera Turbo when I find exactly the vehicles I want.
    1986 944 Alpine White, owned from 1994 to 2006, acquired at 58K miles, sold for $900 less than I paid for it, and with 203K miles!
    1999 C4 Zenith Blue, great vehicle, and wonderful in winter with Blizzaks. 2006 to 2019.
1,314 profile views
P2C4's Achievements
  1. From the digital readout on my 2012 Cayenne Turbo, the normal coolant temperature on my care is 201 degrees F.
  2. 2012 Cayenne Turbo -- I've had the same issue. Every few weeks, typically as I begin driving before reaching operating temperature, the low coolant level warning message flashes slowly, and the coolant temperature gauges (both digital and analogue) will run up to 255 degrees F. Then if I touch the brake, or the accelerator, or hit a bump on the street, the temperature gauges revert to normal levels (201 degrees). I know the coolant level is not low. And several time when it has done this, the engine isn't even up to operating temperature yet. Happily, the digital oil temperature gauge in the instrument cluster never seems to show these fits of variation, and is always in the reasonable range. There is no regularity to when the low coolant level and high temp gauges act like this. But they always reset quickly, within a few seconds if I barely touch the brake or accelerator. Coolant and coolant pump were changed by an indi shop in October, first time it acted up like this was in February (winter here in Utah). Next time it did it was in May. Then a several times in June, and now a couple times in July. Is it the gauge? A temperature sensor? The engine coolant is definitely not overheating when it does this. Any suggestions?
  3. 2012 Cayenne Turbo, 209K miles. Stock Prosche parts and tuning. Durametric reads these codes, if driving around city streets not in sports mode. P1071 Mass air flow at idle speed implausibly high (fast deviation) P0068 Mass air flow implausible. Value below lower limit value These codes seem contradictory. Seems to idles and perform perfectly, and the auto shut of feature, activated with brake on a stop lights, also works as before. Air filters are new as is the MAP (Manifold Absolute Pressure Sensor). Wires seem securely attached. This is baffling. Any thoughts or direction?
  4. Durametric reader, shows two engine codes: P0346 Camshaft sensor 2, upper limit exceeded. P0050 O2 sensor heater control circuit (bank 2, sensor 1), no signal/communication. (It's December and cold in Utah near the mountains.) Vehicle seems to idle and run well for 206K miles. Suggestions please on what to do and how to proceed with these codes? Thank you.
  5. For the last 9 years (and over 140K miles) my daily drive has been 1999 C4. I live in Sandy, Utah, near the mountains (15 minutes from Snowbird), and somes take this car up skiing (skis inside the car always). It does well in the snow, with 17" Blizzaks during winter months. I use no more than 36 front 38 rear, and a pound or two less if there is a fresh foot of snow to plow through. Sunner with Michelin Sport Cups 33 front 35 rear, since it gets over 100 degress most of July. Too high pressure especially on winter tires, on a freeway gives you the feel of fishy tail as you change langes. Too high a pressure on summer tires and you feel too much of the road imprefections, for comfort. Standard suspension.
  6. Thanks for this thread. I just replaced mine in my 1999 C4. $14 for same part number: 996.606.103.01. Hardest part is locating it, which isn't hard -- took toward the front of the car, that end of the tranny; mine was on the passenger side. Needs a 19mm wrench with short handle, or of course a crescent wrench.
  7. 1999 C4, 182K. Runs great, strong, no oil leaks, or issues (I've owned it since 38K miles). There's much to be said for ontime, regular maintenance.
  8. Thanks for the direction and courage it provided, Loren. The cover is located above the passenger foot. There is a small Torx screw, in the middle of the cover, right near the bottom, i.e. the hinge line, of the glove box. It helps, or is necessary, to remove this. Pull the cover down at the glove box hinge line, then pull it slightly forward, to remove. It takes a strong pull to pop it free. There is also a plastic air channel tube that has to be removed before one can see the image under Loren's #2, above. A 7/32 socket will remove the two screws that tightly cover the opening to the particle filter. Now that I've done it, it could be done in three minutes.
  9. Can some one get me started, on how to change the cabin air filter, or particle air filter, on a 2009 Cayenne V6? It is definitely different from the DIY for 2003-2006 models. thanks in advanced.
  10. Thank you Loren; I appreciate, and trust, your expertise.
  11. Thanks Loren. And then do you always replace rotors in pairs? And does replacement of rotors necessitate replacement of lug bolts?
  12. Loren: Per your post above, at August 09, 2012 - 09:44 AM: If a lug bolt hole is stripped, are you recommending replacing the rotors on both sides of the car, and replacing all the lug bolts? When would one replace lug bolts in the normal course? if they get rusty, or just age? Mine is a 1999 C4 with 177K happy miles which I've owned for the last 140K miles and 9 years. Thanks in advance.
  13. So, I at mghorayeb's insightful and most helpful (if less than obvious to me) suggestion, I obtained a whole new roof cassette assembly (everything but the motor) on ebay shipped to me for $360. It came complete the the exterior painted roof panel, which was replaced with my own. The part was was from the same model and year as my car, but one with half as many miles as my car has. Thank you mghorayeb. That saved me $1K in parts. My local shop charged me $600 (i.e. 6 hrs) for the remove and re-install, and it works well now, again. Moral: I think I kept my roof lubed, but I'm sure to continue to do that now.
  14. Mghorayeb, thanks for your reply. I took the car to my Porsche mechanic, a shop dedicated to Porsches and European cars. Apparently the sliding roof has come off its rail on one side, and he thinks a cable is broken. He's quoting me $1400 in parts (including a "cassette" and two other less expensive parts, but not including a motor, since my motor is apparently OK), and 5 hours of labor. I'm more than a little surprised that fixing a sun roof is about a 2K hit. Does this seem reasonable and appropriate?
  15. 1999 C4, which I've owned and enjoyed for 7 years, since 38K miles (now 159K miles). This evening the sliding sunroof was sliding open nicely. It only slides open if I hold down the button. But then a slight bit of rough road, at 35 mph caused it to hick-up a bit (clicking noises). And I probably briefly pushed the wrong button(s). Now it's wide open (slid all the way back, i.e. roof open to the sky). It will only shut about one inch, then stops. And repeated attempts make it close back up only result in opening back up that one inch. The tracks look clean, and were last lubricated 2 years ago. I don't use the sunroof much, other than the slight tilt up to vent. Suggestions on how to get it to close, and how to fix it? Manual close doesn't work -- can't get the supplied wrench to close it, because it's too hard to turn, and I don't want to force it, and goof something up further. I don't see any thread here that addresses this stuck open issue, and re-teaching in this circumstance doesn't seem to work (I tried it). I appreciate your suggestions and wisdom.
