Al4S
Everything posted by Al4S
  1. Thanks Loren, that is what I thought. This would be located up by the window relay and flasher correct? Or is that what the 4 mystery wires connect to. I have had some luck today. I have traced some issues to the light switch, this appears to have been burnt out at some point and causing earthing issues but I still have the problem with the wipers not working and indicators not flashing. Thank you guys
  2. It’s a1985 911 3.2 Carrera. Thanks
  3. Hi guys, looking for some help with the wiring behind the dash on a 911 3.2 Carrera. My customer has fitted a new loom behind the dash and repaired the instrument wiring. I’ve managed to sort out the fuse box wiring connections and corrected the wiring to the clocks/Speedo etc. I am having a problem getting the wipers and indicators to work. The hazards work when activated but the indicators won’t do anything. I have wiring diagrams but can’t seem to indentify 4 wires. They are located up by the cigar lighter wiring behind the dash panel. The wires are red/black, black/blue, brown and grey/Green. Any help would be greatly appreciated. I also have a relay 911 618 102 01 which I can’t find a location for. Thanks in advance for any help
