Brian Zaniboni
Everything posted by Brian Zaniboni
  1. The lights are now working have no idea why but they work
  2. Bulbs are fine thanks for all your help I really appreciate it
  3. Yes the led lights are working
  4. Just checked bulbs seem to be ok but when I get a chance I will change both do you happen to know which fuse might control these lights
  5. Ahsai vanity mirror lights are working. Do you know how I can get the cover of lights on the lower section of the door panel off so that I can check the bulbs
  6. Ahsai i will check that out first thing in the morning. I also found it odd that they both stopped working at the same time. Maybe I'm looking at the wrong fuse also
  7. Ahsai the window drops when you open the door then returns to fully up when door is closed. In fact everything else seems to work fine
  8. The lights on the interior door panels won't work . Checked setting on overhead also checked fuses. Seems weird they would both stop working at same time. Anyone have any suggestions as to what the problem might be....Thanks
