Jrfishel1
Everything posted by Jrfishel1
  1. Thank you Loren
  2. If you could help, I have a Becker CDR-220 type 4462 serial XS050767 thank you again
  3. I have a 2003 Boxster base model (2.7) with auto. Current showing code P0600 and DTE 61. Had a few different Porsche mechanics look at the issue and have not found a solution. Cleaned the electrical connection at the transmission and verified the ground connections at the tiptronic control module. Had the DME, tiptronic module and immobilizer checked and they were found to be working. Does the Can-bus connection between the DME and the tiptronic module extend to the immobilizer or other modules? All I could find is information up to the 2001 model year. Looking for a reason why the DME Is not communicating with the tiptronic and how to test the Can-bus circuit. Is there a wiring schematic available for the 2003/2004 boxster? Thanks, jason
  4. Good afternoon Loren, my new project has a CR-220 in need of a code. Thank you for your help when you have time. thanks, jason CR-220 Serial: XS019711 Type: 4362
  5. Thank you
  6. Good afternoon! I have a radio in need of a code to unlock: thanks, jason CR-220 Serial - ys023240 Type 4362
  7. After doing some research, I cannot find a clear solution to this problem. I have a 1997 Boxster which has a problem with the window controls. If I remove the convertible top relay (double relay), both door windows operate as expected (proper drop when door is opened, auto drop when you press the window control, and full motion up and down). When I insert the top relay (even with the top latch closed), both windows drop the standard 3 inches and the driver’s window will only go down. Once the driver’s window goes all the way down, it will not go up until I remove the top relay. Any thoughts from the community? thanks, jason
  8. Donation made
  9. Good evening and thank you in advance CDR-220 Type 4462 Serial- xs024430
  10. Thank you
  11. Thanks again for your help! CDR-220 type 4462 serial number WS006225
  12. Thank you
  13. Lost my radio code, let me know if you can help. Thanks Becker CR-210 R1996 Radio serial number: Vs005535
