MagnusB
Contact Methods
  • Website URL
    http://
  • ICQ
    East Bay
    2007 997 S
  • Future cars
    997.2 GT3
    99 996 C2 cab
    04 RX-8
    Volvo Amazon
978 profile views
MagnusB's Achievements
  1. Exactly same issue here. What part and where do I buy it for $115? I see prices way above that.
  2. My PCM broke and I bought a used one and replaced it. Most things works just fine but I lost the "individual memory" and "sports chrono" settings etc. It also nags me with an error on startup about the Navigation. The car it came from had a navigation unit. My assumption is it would just be to load the codes with a PIWIS and remove the Navigation unit and CD changer it thinks it has? I had it at a dealer and they say they can't get it to work. If I understand the notes they can't load the codes for some reason. Any ideas?
  3. My Dension 500 works great with bluetooth but you need that blue extra "box" connected.
  4. It was the Master Brake cylinder :-)
  5. Do you know which bracket? I get a noise between 2500-2800 rpm. Extremely annoying.
  6. What can this issue be? - Firm brake pedal with engine off. - Soft brake pedal giving way all the way to the floor slooooowly with engine on. - No visible fluid leakage and reservoir level stays same even if I continue pumping the brake over and over. I have tried bleeding the brakes with Motive Power bleeder to see if that helped but no. Is it the Brake booster or something else?
  7. Turned out to be a cracked clutch finger disc resulting in uneven fingers. So when releasing the clutch about 75% of them hit the clutch initially which was causing the juddering.
  8. Thanks, something to do tomorrow :-)
  9. 30k miles on both. How do you bleed the slave cylinder?
  10. Today on my way home from work something happened with the clutch. It feels fine/normal when pressing down but when I release it hesitates/judders and the engagement feels weird. Once it's up the car drives fine in gear. The weird thing is that when the engine is off it feels normal when I press and release the clutch. It does squeak a tiny bit though. If I start the engine, in neutral and press/release I feel the judder on the way up.
  11. For the small part, how?
  12. I tried to remove the panel but the rear seat holder uses a hex bolt of some weird measurement. Metric 2.5 is too big and 2 is too small. Grrr. Do they use US sizes in a Porsche??
  13. How did you replace it? I need to open everything up and see what's wrong with my left rear quarter window. There was a bad noise and now it doesn't work. I can hear an engine noise but nothing happens.
  14. Will a 2002-2005 6-speed manual transmission work in a 1999 car?
  15. How do you calibrate the top? I have the Smart Top. When opening with the Smart Top the cab closes properly but the lid stops two inches from closed for some reason. If I then use the button it closes properly.
