captain caveman
    South Wales
    996 C2
captain caveman's Achievements
  1. I was wondering if anyone had swapped over transmissions with different codes, Thanks for the link but dosent really tell me what i need to know.
  2. Looking for a gearbox for my car and been told from a breakers there's at least 3 different transmission codes for my car (c2 manual 3.4) with is fitted with a Getrag box with lsd. Anyone know if these boxes are interchangeable? Im not to worried about losing the lsd if i have to.
  3. Went out to the car this morning turned the key dead nothing at all. Popped the cover off the battery to find the earth lead had come off! So for once a quick easy fix.
  4. While driving home tonight ive noticed that when i break the radio flicks off for a second also the headlight flick at the same time. Also not noticed if i turn on the heated rear window it has the same effect on the radio. Then lastly got out and my remote locking on the key has also stopped working. Any ideas?
  5. All sorted now, The cable had pulled apart under the car.
  6. Hi Looking for a transmission for my 3.4 as per title. Cheers
  7. Ok so just changed my stater motor (What a pig of a job) Everything back together but now the car is idling hi, Looking at the photo you can see the flap is open a bit and the cable pulley is not resting on the stop. Should it be? Can anyone see what the problem is?
  8. I,d be happy if my keys just opened the locks at the moment.
  9. Hi Mitch i was just refuring to the link that Hilux2400 posted not seen yours.
  10. Bit baffled now the link you posted is linked to a vid i done a couple of years ago nothing to do with cars?
  11. All dry under the seats and no sign of any water damage or damp, Only have the one function on the key and holding it down does nothing either.
  12. No noise at all from the car and the other key doesn't work at all.
  13. New battery in today fob is working but not locking the car? Once or twice ive unlocked the car with the door lock opened the door and the horn has beeped. If i don't turn the ignition on the alarm (horn) would off.
  14. Cheers Loren i now have sound
