EricGT3
Contact Methods
  • Website URL
    http://
  • ICQ
    03 TT
    GT3, 993 TT, 911S, 911SC, Carrera, Cabrio, 930
EricGT3's Achievements
  1. Where is the amp? Sorry, I'm so lazy to explore....
  2. I have an 03 TT with Nav PCM (MOST). I think it's 2.0 version. I do not have a CD changer and it seems there is no pre-wiring for the CD changer up front. I want to install the Dension ipod unit. I believe I will need to somehow get onto the MOST ring at some point. Should I connect through the amp? Or is there a connector on the radio head unit in the dash? Will I need another MOST harness from the dealer? Just want to have everything ready before I tear into the car. Thanks
  3. First you must remove the little caps on the inside of the struts. You want to pry off the caps carefully otherwise you may damage the fastener. Loosen the bolts that hold the wing. You will need a torx screwdriver. Then put in the shim, the wing sits on top of the shim and it will add angle to the wing. The shim is visible after installation.
