Cayenne1992
Everything posted by Cayenne1992
  1. Hello people, I have a few questions, oil level on the Cayenne S should be measured when cold or 65c oil temperature? Because I measured it in cold and its in the middle of the dipstick and with the hot oil its full. And also my A/C works perfectly in every fan speed except on 1. It works on 1 only if I put it on another speed and after a few seconds lower it to one. I hear the blower motor making like a squeak sound.
  2. yeah sorry for the term, that why I used the " ". Thanks again for the help
  3. Thank you guys for the reply. Yes, you're right, with AC on the guage rises just a bit. I also thought of a bad thermostat, but if its stuck open why does it still "overheats" past 80c?
  4. Hello guys, I have a doubt with the Cayenne, I've been having an issue that i dont know if its normal. The car sits at 80c or 180f normally but after a 40 min ride the temperature rises a bit then goes back to normal. The temperature rises when i drive to a stop or driving very slowly. Also when coasting downhill on the highway the temperature drops to around 60c or 140f. Is it normal? I attach a picture of the temperature when it rises
  5. Hi, im having the same problem as you, found out what was causing it?
  6. Hello, i have the same problem as you,did you resolved it?
