jabcas
    Chicago, IL, US
    2002 Porsche 996 C4
jabcas's Achievements
  1. I'm still stuck on thinking it's the DMF too. The only other 2 things I can think it could possibly be is the exhaust touching something it shouldn't be or maybe the harmonic balancer. I guess I will go ahead do the coils and plugs though anyway since the car's at 80k now.
  2. I'm also wondering if you got it resolved? Mine is vibrating like crazy when sitting still in neutral or driving. I can feel it everywhere in the car and on the car. There is a ton of vibration on the rear fenders and bumpers. You can also feel it a lot in the clutch pedal especially when you push it towards the floor about an inch. You can also feel the motor vibrating more than usual if you touch it. This vibration can be felt at any RPM and gets worse the higher it goes. There is a point between 3.5k and 4k RPM's where it's goes from bad to worse. When it's in that range or higher you can actually hear the vibration. So far i've changed the motor mounts, trany mounts, IMS and Clutch. The shop said there was nothing wrong with the flywheel and recommended not changing it. It vibrates regardless of temp. There are no check engine lights on. There are no other odd noises happening to make me fully believe it could be the flywheel. The shop said the car did show some misfires and said maybe changing the plugs and coil packs could solve the vibration problem. Would plugs and coils actually cause that much of a vibration issue? It doesn't seem likely to me.
  3. Mine look like this. Maybe someone swapped them out with something different?
  4. Does anyone know where I can purchase replacement plastic clips for my hardtop? Right now the interior panels are removed because half the clips are broken.
