John Hopkins
Everything posted by John Hopkins
  1. Adding reply because I forgot to check " Notify me of replies"
  2. I discovered that my car's headlight level sensor in the left wheel well is missing some parts. It has the sensor and the vertical bar that connects it to the control arm. It seems, though that there is nothing on the control arm to attach it to and the lower plastic bit on the vertical bar is broken. It seems strange that the clip on the control arm would be completely missing. I don't even see how that could have happened. So, my questions are: Is there supposed to be a level sensor on just this side, or should the other side have one as well? Should actuating the sensor manually while the car is running make the headlight do anything? When I start the car, I see the headlights do some sort of leveling and it looks like they point at the right angle. Is there some other sensor contributing to it leveling?
  3. I agree. That said, Loren posted above, the msrp. My local shop is charging about 20% more. Not that it is a big difference in this case, but out of principle I don't generally support businesses that sell above the MSRP. Where can I find the MSRP to confirm.
  4. Thanks all. I'll reach out to my local shop in the morning for a new cap. Is there a better place to buy from?
  5. When I'm driving it, I top it off regularly. It has a small coolant drop from the front that I've yet to repair. Waiting for some warmer days to pull off the front bumper. I don't see any 04 anywhere on the numbers. I'm guessing I have the old one.
  6. Thanks guys. I'm liking the cross threaded cap. That would explain the clues. I thought, initially, that it was a cracked tank as I'd read that those were an issue in older cars... but I think it would leak again when I refilled it. Would the incline of the car have anything to do with it? As I mentioned, the leak trail didn't start till I drove up my short but steep driveway. Also of note, today is the first "warm" day I've driven my car since winter started.
  7. I don't drive my car much in the winter months. Today was a warmer day (60º) so I took her for a drive, just about 25 miles round trip. There were no issues until I got to the top of my driveway. The last 10 feet or so left a trail of coolant. The coolant continued to pour out of the car for next few minutes. It was as if it was coming from the overflow in the trunk. I inspected for issues and couldn't find a culprit. There has been no coolant added since well before winter and I've driven it several times since then. I poured some hot water into the overflow area to flush out the coolant and then refilled the reservoir to appropriate levels and let the car run for a bit to see if it would repeat. No leaks after that. I'm not yet as familiar with this car as I am with some others. I'm wondering if there may be an issue with the coolant bleeder valve. Anyone have an idea what may have caused this?
