Hroussard
Everything posted by Hroussard
  1. Here is a picture of my baby seat
  2. I have a 1999 C2 and I have a BRITTAX seat in the back which fits perfectly. My son is a tall 5 year old and has no problems sitting in the BRITTAX seat in the back for long distances. Note that I can not have the passenger seat all the way back because there would not be enough space for his legs. Of course when he is 6, he can sit normally in the Porsche back seat as per the laws in California. In general, the problem with a child car seat for the Porsche is the fact that the actual bottom of the seat is TOO WIDE ( left to right ). Seems the ONLY seat that can be adjusted down from 17 inches all the way to 12 inches is the Brittax. That's all it takes to make that seat fit perfectly. Note that I do not use ( and never have) the back of the child seat. I am using the seat more as a booster seat at this point . If you do use it with the back attached, you may find that the backrest of the child seat is pretty upright ( read uncomfortable)...I think a little too much for Cab and you may think about taking the Porsche backrest out and use the Brittax seat back instead of having the Porsche back rest just taking up space there.. If you use the Brittax seat it will bring the seating space several inches forward ie you now have TWO backs which will reduce the seating space between the backrest and the front passenger seat too much. I paid 70 bucks for the car seat. The way I tried it out is that I drove my car to a Kid-R-us type shop where I knew they had the Brittax seat. I just tried is at the shop and as I said , it fits perfectly after I narrowed the bottom seat which, BTW, has even arms rests. I can make a picture if you are interested. Cheers HarryR
  3. I moved from the European continent to England and took my DeTomaso Pantera with me. This is many moons ago but because the fact that the road system has really not changed too much for the general roads in use there ( excluding Motor ways - freeways), I believe this statement is still valid. I almost killed myself on one of the narrow roads, tagging allong behind a bus...seeing a space to overhaul and only finding out that the space to overhaul was getting small in a hurry. I managed to throw the car back onto the left lane in time to avoid the opposite traffic. That was the moment I decided to sell the car.. Which I did within a week or so. Trust me it's a ROYAL pain to check traffic from the wrong seat in the car and / or trying to rely on a co-pilot to tell you "it's safe to overhaul". There is obvious not such a problem on a wide open freeway. Also the comment of having the ability to drive into Europe with the steering wheel on the left hand side, although true, does not really help lots of folks because the only time you end up in Europe is on a 2 week vacation and you might be better of taken the Airplane down to Spain , Portugal or Italy - that's where it is warm enough for a vacation folks - because of the traffic in mainland Europe. Oh.. and did I mention the cost of the gasoline driving down South?? Charter flights to the South really start at 150 bucks for one week INCLUDING 2 meals at least. Cheers HarryR
  4. Simple Green is a great product . Be aware of the fact that the standard Simple Green MAY NOT be used on aircraft ( aluminum) because UNLESS it has been washed off TOTALLY it MAY induce corrosion. As such they now have a new product called " Extreme Simple Green ", " aircraft and precision Cleaner. Meets Boeing spec D6-17487P. Non corrosive . Check the Website www.simplegreen.com There was a special offer. One full 32 fl.oz. bottle FOR FREE a month or so ago. Call them on 1-800-228-0709 HarryR C2 1999
  5. Not sure about the logic... They are a limited edition. So if you are prepared to keep the car for 20 years or so and not drive the hell out of it, you could see the benefits. It's supposed the best of the best of the type. 6 of one , half a dozen of the others. However, a turbo always seems to always attract a lot of passion...and can be sold more easily. So if you buy with as plan to sell, a turbo might be the right deal.. Cheers HarryR
  6. Yep, happened to me 6 months ago. 1500 dollars total which included the parts ( also an upgrade part is needed for one of the small water pipes), did not include the serpentine belt. Cheers HarryR C2 1999
  7. "" You wrote: am i correct in assuming that 425ma is the same as 4.25amps? "" Nope... That is 0.425 Amps Good luck! HarryR
  8. I will try that one but I had the locking mechanism for the front deck lid replaced last year and my hood is flush. I will check that out. The sound is indeed a squealing sound but it sounds more as if it is coming from a friction like a brake pad having continuous contact with the rotor, it sounds definitely as if it is coming from the back. As I said, the car has to move, the volume increases somewhat from 30 miles onwards ( that's the speed at which I start hearing the sound), I have observed no leaks, or funny/burning/hot smells, no smoke of any kind and so I guess I will keep on driving until I figure out what it is or until something changes that lets me pinpoint the issue. Thanks HarryR
  9. Folks, my car started to make a whisling noise. Here is when it happens: 1/ Over 30 miles / hour 2/ Independent from engine speed and /or clutch engaged or not 3/ louder when speed increases 4/ no change with or without a/c engaged 5/ No change when braking or not 6/ no change when turning The sound is a medium pitched constant sound, almost as if a brake pad is touching the rotor but it does not change if I push the brakes. It does get louder when speed increases and is audible from within. Noiae doeas not seem to be louder outside the car ie driving with windows down does not increase the loudness of the sound. Idea's?? HarryR
  10. DFo yoou have the radio antenna enbedded in your front windscreen? if so try to mount the sensor to the side and below or above that vertical and horizontal wire that runs through the glass. HarryR
  11. I am interested in 2 knobs for my CDR-220 ( C2 1999). If there is someone that has to buy more that 2 knobs ( minimum quantity purchase as mentioned above). I am happy to buy them from you. Send me an email hroussar@yahoo.com and we can finalize. Thanks HarryR
  12. I had a look around the Weissach web site and I found this picture. I particularly like this wing because of the crease that runs horizontally between the rear lights. Does anybody know about another wing (from a different manufacturer) that looks like that and can be purchased separately at a reasonable cost? This the first wing that I actually like because it looks like a factory designed and installed item. HarryR C2 1999
  13. Folks, I have not seen any posts on the pro or con of installing a Tower Strut brace. What gives?? HarryR
  14. The Short Shifter is IN!!! My thanks to Loren who single handedly ripped and replaced the shifter in less than one hour. The B@M shifter looks and feels like a real well machined part . The original Porsche shifter looks like a Yugo part held together with plastic Yugo parts. The instructions coming with the shifter actually were correct , a pleasant surprise but Loren has developed some short cuts and work arounds that eliminate potential problems with adjustments that might be needed after installation . The net of it is , there are no adjustments needed ( provided the original shifter was adjusted correctly). Performing a quick test drive to ensure that the shifter works correctly before "buttoning up " the console is a must. So, I climbed in the car and engaged the reverse gear however, it seemed it was not there, the throw seemed too short and there was not the little "feel" ( that little notch that tells you that you have pushed the level as far as it will go) that the gear was engaged. Turns out that the lever had indeed engaged the reverse gear, it was in and working perfectly. The lever moves nice, firmly and notchy thru all the gears. As I have read now many times in the Forum. It's one of the better mods, especially for the money. Loren, thank you, a donation is on the way. Also attending was George C. who looked on while Loren performed the deed and subsequently did his swap, also in about on hour. George obviously has been using a screwdriver a few times :) George's Carrera 4 Cab, yellow, surely looked the part especially when I was chasing him on the 101 through San Jose at speeds slightly over the speed limit. Just to test the shifters of course. :) HarryR C2 1999
  15. The fan on the engine lid is not for air extraction, but is an intake fan. It draws cooler air into the engine throught the lid when the engine compartment gets above 180F. You would NOT want to draw air out through the id as this would increase the engine temperature. <{POST_SNAPBACK}> Of course, you are right on the subject of the fan in the engine deck lid.... my mistake. HarryR
  16. Carlos, yes the A/C problem has been fixed, it was a stuck expansion valve, they recharged the system and it's delivering absolute freezing cold air it this point. They also checked all the electric fans for correct function AND cleaned the leaves etc from the air intakes. I am watching the temps and if I feel that the system is over loaded ( running too hot ie needle over or to the right of the zero in 180 in the gauge) I will certainly think about it again. Interestingly, I have not yet seen the extraction fan in the engine cover lid come on. More to come I am sure. Some interesting titbit I picked up somewhere else on the same subject.... It seems that certain car manufacturers have decided that the temp gauge is not much more than an idiot light ie , cold, warm and TOO hot ( light goes on) and that the temp needle basically moves from low to the middle and stays there unchanged until the engine overheats, in which case the needle with go to the red sector ( equals the idiot light setting). This seems to be in an attempt to pacify folks and reduce the amount of calls the dealers get with " my engione runs hot " concerns because "the needle moved" . Interesting.. HarryR
  17. Loren, Well, I got my B@M Short shifter and I emailed George who was expecting his unit last Friday. When would you have time to help getting these 2 shifters installed?. A week-end (Saturday or Sunday) would work for both George and myself. Suggestions please?? HarryR
  18. I think the wheels on that Cab look great. But if it would be me, I would be looking to get rims with a MAJOR lip front and back. That, in my mind gives a much enhanced looking side view and frankly, I feel that a wheel looks much more balanced if the inner part (spokes and lug nut part) are more towards the middle of the rim rather than look like an "endplate" with holes for cooling or looks. My 2 cents. HarryR
  19. Any idea why? <{POST_SNAPBACK}> no clue....my deck is rated at 50wattx4, the amp is at 45x6 and the speakers r 45 watt. maybe just bad luck the amp went..or maybe the amp didn't like the deck. 'm not much of an audio guy...i just kno what sounds good, and get someone else 2 do the install work lol <{POST_SNAPBACK}> I have a Nissan Maxima with a Bose system, I had a 300 ZX TT with a Bose system and I do like them ( in the car) . The issue I have with powered speakers is the expense when something blows up ( and believe me it does blow up) and in general with the difficulty in making any changes to the whole or part of the system. That's not customer friendly... Cheers HarryR C2 with Bose :cheers:
  20. Here is something to smile about ( maybe). I friend of mine worked in the audio business and competed against Bose. Here is how they described BOSE : No hights, no lows...must be Bose Cheers HarryR :clapping:
  21. Folks, these concepts are very well understood in the aviation engine business were you can buy pre-oilers to "squirt under pressure" oil through the engine so that when you start it ,you have less or almost zero metal to metal contact because oil will have dripped down from the moving parts and left them basically bare. It also is a fact that these engines will generally only attain TBO ( Time between Overhaul ) IF the engine has been run OFTEN and ( funnily enough) HARD. That means flying several times per week , such as in flying school use. FYI generally TBO is 2,000 hours or 12 years whichever comes first ,after which you will need to disassemble the engine, inspect the parts and replace to overhaul specs ( or new if you want to spend the money), reassemble, run for 50 hours on mineral oil to seat and then change to straight weight oil or multi viscosity oil. For aviation, as you are generally flying up in cold air there is a huge disagreement as to which oil is the best. These engines are generally 360 cubic inch , 4 cylinders, flat four and air cooled , the larger engines are up to 540 cubic inch and have 6 pots. And so you get an idea... they most always run at 70% to 100% of power. You Porsche engine will generally run at 25 to 30 percent of maximum power. Porsche built such a 360 cubic inch engine for the Mooney aircraft and that engine worked very well indeed, unfortunately they decided to get out of the business and I believe that, it this point in time, almost all of the engines have been replaced ( on Porsche's cost for a great deal I may add) by LyCo or Continental engines. But..in general. oil will remain on the moving parts for several days before it's all dried up or dripped down into the oil pan, so the best thing to do for your car is to use it as your daily driver, fire her up, keep the revs down until the engine is HOT and let her rip from then onward. Cheers HarryR C2 1999
  22. I don't know if this helps but I also have a C2 1999 and my A/c just did not chill. Investigation by Carlsen in Redwood City showed that the expension valve was not working. The part number is 99657392901 and together with some o-rings that valve was about 180 bucks. They had to empty the a/c system and refill it which cost additional. The total job took abour 3 hours or so.The air is now ICE COLD!! Cheers HarryR
  23. Thanks Loren, I hope we can plan it that way. I will bring the wine.... HarryR
  24. Harry, I am also getting the B&M very soon. Let me know if you are going to do the DIY installation. I would like to drop by to help and watch if you don't mind. George <{POST_SNAPBACK}> George, I have 2 left hands so I am afraid I would not be safe in attempting the installation. Graciously, Loren has suggested he can help ( I hoop he still remembers :-) ). I still need to get that organized. Send me your contact info and I will talk with you as soon as I know when this "event" will take place. Maybe you could attend... email hroussar@yahoo.com This morning I visited Carlsen in Redwood City and talked with Brian H. . They are also seeing to a leak I seem to have in my a/c system. Expensive repair OUGH!! Brian is taking good care of me . Thanks B.!! But.... they had 2 GT3's with standard manual shifter and one Turbo Cab with the Short shifter ( factory) installed and the difference is AMAZING. Yes , this much more notchy and it needs more effort to change gears but it turns the car even more into a real DRIVERS machine... I tried Loren's shortshifter( in his C2 ) a while back and that is AS GOOD AS the Porsche version , maybe even slightly better. I am sold. It reminds me of my DeTomaso Pantera a while back... actually a LONG time ago. I also met Carlos there and saw his Carrera. The car is going fast standing still. Very nice ..in english english... Bloody nice indeed. Cheers HarryR C2 1999
  25. Folks, I am contemplating to have a 3rd radiator added to my C2 ( 1999) and I am wondering : 1/ what does the radiator cost? 2/ what is involved in the installation? 3/ how much would installation cost 4/ what temperature drop could one expect compared with the stock 2 radiators? The reason? I feel that the engine ( here in California) is running pretty hot ( gauge is indicating between the 8 and the zero of the (180) number and sometimes goes just on top of the zero number. Cheers HarryR PS Loren, I just bought a B@M short shifter today ( eBay at $ 199.00 plus freight). I will be looking for your help :-)
