Cyttse
    Hong kong
    2007 cayenne turbo
Cyttse's Achievements
  1. Sometimes the bonnet switch do affect the wiper, when the computer think the bonnet isnt completely locked it will stop the wiper motor from working. There should be some breach of the circuit for making the pcm not working properly.
  2. No idea. Thats from what I observed. Now I took off the new ballast and everything back to normal.
  3. I finally figured out why the PCM and the wiper not working, it is the headlamp ballast! I bought the ballast from Xenonland. https://xenonland.com/productv/40573/hella-xenon-ballast-control-unit-for-porsche-cayenne-2007-2010.html They gave me the part 97061814302 and insist thats compatible to my cayenne though I believe the part should be 955631194xx. I unplugged the ballast and everything back to normal including the pcm and the wiper. When I plugged that in, the headlamp worked but some of the electronics control unit were lost and could not be read from the diagnosis.
  4. Yes the jet washe is working but the wiper just not moved. I just thought maybe that was due to the xenon ballast? I just changed the ballast and the starter then after all the pcm and wiper were not working. I bought the ballast from xenonland. Well I did order by the factory part number but endup they sent me the part 970.618.143.02 instead and they told me that was the latest part number. My mechanic told me they couldnt find the xenon unit and the pcm in the computer now... Thanks for your reply. I had my new batt replaced in just 3months ago thats why I didnt think about that was related to the batt before. My starter seems working badly before as it needed more than 5 times to make it start. The new one seems working well now. Anyway I ll try to measure the the voltage again tonight and see. Or I ll disconnect the batt for awhile. Disconnected the batt for a night but no luck. Will try put on a new batt or what next week. Annoying.
  5. tried to put another new batt on my car but no luck.
  6. Your front wipers not working???? I have exactly the same issue as yours! I just found my wipers not working too but its not about the motor.... so weird...
  7. Thanks for your reply. I had my new batt replaced in just 3months ago thats why I didnt think about that was related to the batt before. My starter seems working badly before as it needed more than 5 times to make it start. The new one seems working well now. Anyway I ll try to measure the the voltage again tonight and see. Or I ll disconnect the batt for awhile. Disconnected the batt for a night but no luck. Will try put on a new batt or what next week. Annoying.
  8. Thanks for your reply. I had my new batt replaced in just 3months ago thats why I didnt think about that was related to the batt before. My starter seems working badly before as it needed more than 5 times to make it start. The new one seems working well now. Anyway I ll try to measure the the voltage again tonight and see. Or I ll disconnect the batt for awhile.
  9. Can you use the steering button when the key not turning to ignition? Is the navi working?
  10. Do it need the code if I buy another second hand pcm?
  11. The funny part is when I insert the key it works fine as normal, the rear camera working, the steering control button works. But when it turns the key to ignition, it doesnt and appears like engine off and shut off....
  12. Is that I need to enter the code for the pcm and how can I find it?
  13. I have tried both of the methods but it seems not work.. The starter motor not working well therefore I need to change it. And I did change the headlamp ballist at the same time but without correctly coding it yet ans therefore there is still fault code of headlamp on the dashboard. Checked all the related fuse but they are all good.
  14. Thanks! Will try later and hope it works. By the way, will the problem related to anything about changing starter motor? The battery was disconnected for a couple hours before and all this happened.. does the pcm needs any coding after disconnect the batt? Hi anyone can help?? I tried dial 148 but it doesnt work after reboot. How to reset the pcm?? Thanks Terry
