Dopeyskydiver
Dopeyskydiver last won the day on June 17 2020
Dopeyskydiver had the most liked content!
About Dopeyskydiver
  • Birthday 08/28/1969
    Amsterdam, The Netherlands
    Other
    1964 356C Coupe
    2011 Cayenne S (Model 92A)
  • Future cars
    2017 Porsche Macan Turbo
7,250 profile views
Dopeyskydiver's Achievements
  1. Piston scoring is a well known issue with the Cayenne S. Don't ask me how I know...🤷‍♂️
  2. Hi Luke, Sorry for the delay - here's photo's of my 2011 Cayenne S right & left side fuse panels. Video is of the owners manual with the layout and descriptions.
  3. Thank you Loren! I will check the wiring first. Just out of curiosity, I believe the valve lift solenoids can not be individually adjusted, but per bank (side). Is this correct? Would it then make sense to change all solenoids, or just focus on #8? (My Spidey-senses are tingling and saying to change them all...)
  4. Hi all, Can't seem to get rid of fault code P1376. It can be reset, but comes back within a few days. (Car seems to run fine) The local independent garage hooked up their PIWIS and verified the P1376 code - said it was something to do with cylinder #8? Has anyone else experienced this - and if so, what was the fix? Any tips/advice is appreciated!
  5. Hello Spoon, It sounds like you have done a pretty good job in troubleshooting... My hat is off to you! 🤠 Since you know: 1. the fuse is good 2. mirror adjustment motor is good 3. folding motor works in both directions when it gets 12V 4. zero volts at the motor plug 5. buttons all work The only thing you have not yet tried, is placing the passenger side adjustment motor in the drivers side position to see if it works. (don't bother) My educated guess is that it won't work because you definitely have faulty driver's side door wiring... Nice weekend job!
  6. I believe the single blue wire goes to the generator, and the plug with two wires goes to the sensor.
  7. I'm pretty sure the 2" opening will be too small. Here are two pictures taken from the front, but without removing the panel, I can't verify. Let me know if you need me to do that.
  8. Penstamin, This information is for my 2011 Cayenne S - should be similar. Hope this helps? Fuel Filler Flap Removal.pdf
  9. False - it can be ordered separately. It looks like the part number is 7PP919238 (possibly with "A" or "B" at the end). Could you verify? If so, they can be purchased for less then €10. The other option is to replace the LED yourself, but I'm not sure of the level of your fine-motor skills or patience.. 😉
  10. I have a 2011 Cayenne S, and both front door security-led’s flash when the alarm is set. Hope this helps.
  11. I can't remember where I bought my workshop manual, but you can still get it for a small fortune here: 😲 NLA Limited : Owners Manuals BIT.LY
  12. Might need to ask my garage to look into it... Just never experienced a “comfort” ride after purchasing it second-hand, and since this is my first “modern” Porsche - I just wanted to know if this request would be worthwile, or if I’m dreaming. I would hate to throw money into something that is normal... Any other Cayenne owners out there that confirm there is really a difference? On a side note: I have 21” wheels, and I understand that will also influence the ride comfort due to the lower profile tire.
  13. After reading this thread, I thought to myself - ?hmmmmm my 2011 Cayenne S also doesn't seem to ride any differently regardless of the suspension settings (it's ALWAYS hard) Comfort, Normal & Sport. Is it really supposed to ride smoothly in the comfort mode? Asking for my kidneys.... ?
