lindog
Everything posted by lindog
  1. the battery is renewed. however, the day after, the car had the same problem. wont started. Only can hear the click sound from the starter, but the car wasnt started. the funny thing is I release the e-brake, then pushed a little bit backward the car. and the car was started. I really have no idea about what I had done to make it started....... really stranger for me. after few days driving, check engine light was on twice, and also battery light was on twice. However, they all gone the next day. Driving is good right now. dont seems anything strange. I dont run the scanner yet. but I can tell there should be some codes, because the time it wont started.
  2. UPDATE: the battery has been tested as weak. Order a new number on the road right now.
  3. 🤣🤣🤣 starting itself yep, i will go to check the battery later.
  4. thank you robert, I will do so. btw, from the code, I cant tell which fuel pump is bad.
  5. hi there, I got a problem with my 2011 cayenne turbo which has 87xxx kms. sometimes it randomly starts. Today, It just wont start at the gas station after i fulfill the gastank. it happened couple times before. I can hear a 'click" sound while i was doing the ignition. however, the engine didnt start up with any other symptoms. First I was thinking is it a security problem, so I try lock the car and unlock it. NO HELP. Then I try to unplug the battery for 20mins. NO HELP. Finally,,,, I got my friends to help me push the car out of SHELL to the parking lot. What a ODD thing..... After about 20, 30 minutes, the car started up again. what the ???? I recognized few days ago, the chk engine light is on. I went to my friend to run a diagnosis. P1284 FUEL PUMP: ELECTRICAL FAULT (UPPER LIMIT VALUE EXCEEDED). P0687 MAIN RELAY (LOWER LIMIT VALUE EXCEEDED) P0562 POWER SUPPLY (LOWER LIMIT VALUE EXCEEDED) P1572 CONTROL UNIT RUN-ON NOT ENDED CORRECTLY(IMPLAUSIBLE SIGNAL) my friend turned off the chk engine light then see if it still comes out. util now, it still gone. plz help me, anyone has this same problem or similar problem? is it a FUEL PUMP problem? or any relay problem? IT IS BOTHERING ME RIGHT NOW. thanks anyone viewing this!
  6. The car just brought in for 9 months. There is no record for any maintain history. I think the brake pads and sensors need to replace. The battery was replace by a new one when I got this car in last year. However, what is a ABS light suppose to? Also that, the steering wheel was too heavy to turn. That is strange and weird. Wah.....I feel I really lucky..... I will never ever try again...... Thx very much.
  7. My 98 boxster has a brake wear light on in 2007 before the winter. The car put into garage for the winter time. In 2008 April, I drove it back on road. The brake light was still there. Couple days before, there are two new lights on at the same time, ABS(YELLOW) and battery(RED) are on too. However I can still start my car. But the problem is the steering wheel is too heavy. Normally, when the car starts, the steering wheell will be light to turn left and right. Right now it is too heavy to do so. After I drove it back to my home about 10 kms, the temperature was went over to 190. I open the coolant cover in rear trunk, the coolant was push out to every where...... Can anyone tell me what is going on in my car? What is the meaning for each light on? How much will be cost to repair those issue? (Approximately range) I am really in hot water...... PLZ HELP ME OUT. THX & BEST!!!!!
