Georgeramosjr
Everything posted by Georgeramosjr
  1. Possible Connection? Just had remote start installed.... 2011 V6 Cayenne. DTE Codes: 00602 00603 C11011
  2. Anyone have the part number for the air-oil separator for a v6 Cayenne. Thank you
  3. Hello all, I have a 2004 Cayenne V6 with 127k miles on it. I am looking do to some work on it but I need advice! 1) What type of spark plug is best? 2) I need to change the oil separator. I can find a DIY for the V6 model or a part number. Does anyone know? 3)which brake pads are best? Which sensors should I get? 4) I also want to do an oil change. Which is the best oil /filter? Thank you in advance.
  4. I ordered it from China. Both let's do the same exact thing. Had a 3rd party guy do it. Sent from my iPhone using Tapatalk
  5. Well we did program they key. It's turns over fine. This one button is the only issue Sent from my iPhone using Tapatalk
  6. Hey Loren, no he did not have PWIS. Sent from my iPhone using Tapatalk
  7. I am going to ask him now. Sent from my iPhone using Tapatalk
  8. Any luck? Sent from my iPhone using Tapatalk
  9. https://vimeo.com/192062005 New Fob only locks and unlocks cars with the "unlock button". The "lock" button will make lights blink but won't lock car. I programmed 2 brand new fobs and have the same issue. Any advice? Sent from my iPhone using Tapatalk
  10. Great effort so far, I have the same issue
  11. I hope this is the fix! If it does work, would you make a video about it?
  12. Ok, hope the fix is a simple battery change. I have the same exact issue.
  13. Keep me posted as to if a new battery solves the issue.
  14. Mine does switch to P with or without the the circuit board.
  15. I have the same issue. https://youtu.be/bdRIqAOZli8 I remove the circuitboard but now I have a few other problems. The trip tonic does not work from the gearbox on the steering wheel, after about 30 minutes of driving the display get stuck on D and it will not show what a switch to other gears including neutral, reverse, and park. Additionally, now there are no lights in the gearbox
