spider
Contact Methods
  • Website URL
    http://
  • ICQ
    texas
    2012 Carrera 4 GTS
spider's Achievements
  1. It sounds like it's not too difficult to accomplish. Thanks for the info Loren! spider
  2. Thanks Loren. Does the pillar trim just pop off by pulling on it, or is there a special technique/tool that is required?
  3. I'm thinking of replacing the black headliner in my non-sunroof 2004 coupe with a graphite gray headliner. How difficult is replacement of the headliner? spider
  4. Wait a minute. They ruin your Porsche top and then they tell you that you will have to pay $1000 to have an equivalent OEM top? They owe you a new *Porsche* top, at no expense to you. Don't settle for anything less than the Porsche factory top, installed at a Porsche dealer. If they get snakey with you, then have your attorney give them a phone call. How did they put a hole in the top installing a suspension? These people sound like morons. Don't let them touch your car. Good luck. spider
  5. Then could the ride height appearance come from a stiffer setup in the rear, possibly making the rear height just a little higher and, in doing so, giving the car a more "nose down" appearance? Whatever they did, it looks good. //// :) \\\\ spider
  6. Hi Loren. The Anniversary model appears to sit a little lower in the front than a standard Carrera. How does the suspension of the Anniversary model differ from the standard Carrera? Does the Anniversary car come with the ROW 030 suspension? //// :) \\\\ spider
  7. Apparently the assist spring in the pedal assembly was dry and was binding against something. It was lubricated and now seems to be fine. Thanks for your help Loren. //// :) \\\\ spider
  8. My 2003 C2 6 speed coupe is in for service right now for a crunching sound and feel to the clutch pedal. The service department told me that there is no TSB on this, however, I recall that there indeed is a TSB. Loren, do you have the number or reference for a TSB on that problem? Thanks! //// :) \\\\ spider
  9. What does the acronym MAF stand for? //// :) \\\\ spider
  10. Thanks Loren! I will get it checked out. Sounds like it's going to be an easy fix. //// :) \\ spider
  11. Hi Everyone, This afternoon I noted that I have a crunching sound coming from the area of the clutch pedal when I depress it. The clutch pedal also requires somewhat more pressure to depress it. It feels like something is binding in a chattering fashion. The sound is not a squeak. It is a deeper sound, almost hollow sounding. I suspect will have to take the car in for service.... but are there any suggestions as to what the problem might be? //// B) \\ spider, 2003 Carrera 2 coupe
