Aturcotte
Everything posted by Aturcotte
  1. I have a 2000 996 with halogens and need to replace them. Will the boxster headlight fit a 996- they seem to be cheaper.
  2. 2000 996 Cabrio also having double beep. getting codes 61 and 58. lights do not open inside cabin with door opening. when manually locking with key passenger door will not lock. I have had both locks out no apparent problems. pulled the immobilizer looked clean and dry. not sure what to do next. independent wanted $400 just to pull door cards off. any suggestions before dealer? thanks arthur
  3. no warranty, mine are almost a year old- LED flickering- plastic lens starting to crack- junk.
  4. Does anyone have an order when looking at connections in engine bay?
  5. Getting double beep on my 2k 996 c2. Changed passenger lock since it would not lock with manual key lock. No help. Got a durametric and I am getting 61 code. Both doors will lock on secure doors. Control modular is dry and appears fine. driver lock???
  6. I am all MAC computers-bummer
  7. I have a 2000 C2 cab. I am getting the lock -unlock with two beeps. if I manually lock it, I only get one beep and the passenger door fails to lock. I am trying to pin this down without having to have it scanned all other function of windows up and down and fob are working. can this be narrowed to either radio ground for theft or passenger door locking unit? thanks!!!
