neil.c
Everything posted by neil.c
  1. It is the water pressure that lifts the headlight washers so if one side isn't working it could still be frozen. It is usually the water in the pipes that freezes (in the UK anyway) as there is less volume, the light could be a faulty sender unit.
  2. I haven't looked but is the rear bushing designed to move to take up the slack? If so it can be moved backwards to allow more clearance removing the need to grind material off of it.
  3. I would start by measuring the battery voltage with the engine running and with it awitched off. The battery voltage should be around 12.2 volts without the engine running and it should go up to about 13.6 volts (charging voltage) with the engine running.
  4. Did it turn over on the bench before it was fitted to the car?
  5. Doesn't the GT3 redline at 8400 rpm? That being the case range 1 ought to start at 100 revs above that.
  6. How long will you be away for? I suggest pumping up the tyres or getting the wheels off the groundand connecting the car to a battery conditioner ( cars in the UK have remote batttery backup on the alarm so you can't leave the battery disconnected, don't know if this is the same in your market).
  7. Shame you didn't grab a picture, but it sounds as though something has made contact with the tyre over a period of time
  8. Looking at the width and offset I think the fronts will fit as 987 and 997 are the same at 8" and 57 mm ET, the rears will be more interesting though as the 997 runs 2" wider rear rims than the 987
  9. Do you not have an econ button?
  10. The diy stuff never worked for me, you most likely have a leak and as it costs about the same to have it diagnosed as it does to buy the diy stuff to me it is a no-brainer
  11. Could be it has expanded in the sunshine I have seen this before on black plastic trim
  12. If it is above the minimum mark you should leave it alone
  13. if there is an abs fault that would also generate a psm fault/ failure brake light switch failure usually only generates a psm failure and not abs failure. sounds like a faulty wheel sensor to me
  14. Must be a good Technician if he can evaluate the life of your cluch down to the last few k miles from the ball of his foot
  15. Did you do this yourself? As just from casually observing the the calipers the 987S caliper looks bigger than the 997 C2 (could be the colour). I wondered if you had any photos of them side by side
  16. Nope bad luck, the car comes 10mm lower it doesn't lower itself when you press the button In the UK there are 3 different suspension setups, standard, PASM (-10mm) and sport(non PASM -20mm)
  17. I have left our 987s for six weeks whilst on holiday without any problem on my return. The 1 Amp motorbike charger could be ideal especially if it has battery condition monitoring, the solar trickle panels could work also if you get any sun this time of year in BC ;)
  18. I agree with what Berty said above, this is how the 986 pse works and as the emissions test probe is pushed past the bypass tube no problems with emissions and it would only cost a few dollars to carry out :)
