4tw_garage
    Atlanta
    1991 NSX
    2005 Cayenne S
    2011 FX35
486 profile views
4tw_garage's Achievements
  1. Hello all, I've been mad busy with work and kids, haven't the chance to visit the project until now. I still need help. Searches showed this post where Loren helped a member with wiring diagrams but doesn't have what I need since I'd need the 955 with air suspension diagram and the 958 GTS diagram. Loren, can you please help again? Many thanks,
  2. FYI, Here's what I'm working on :) Waiting to finish the last steps of converting the headlights harnesses
  3. Hello all, Can someone please help point me to where I can find the wiring pin diagrams for the following: 1. 955 Headlight and Tailight (CS with Air Suspension) 2. 958 GTS Headlight 3. 957 Tail light I'm in the middle of doing the conversion and need some help :) Thank you soooo much.
  4. I'm leading to think that it's the Air Suspension/Body Control module is toasted?
  5. Hello all, Long story short, I had an issue with my 05 CS. It complained about faulty suspension workshop. Turned out that the compressor was not running at all. I bought the rebuild kit, compressor is working again (sounds a lil weak though). Yet I'm still stuck with the warning message. Checked & Changed the battery also (new BOSCH AGM). Upon started up, car says that pressure accumulator is charging. After driving for a while, I was able to use the control pads to adjust heights. Lowering is ok. Raising takes a lil while (most of the time). I bought the Durametric Enthusiast to see if I can calibrate manually. When I try to connect and try to READ, it shows the following: "This channel does not support adaptation" I let it be for a bit, still no info, no movement in the car. After trying it again, it app froze. I tried on 3 different laptop, window 7, 8, and window 10. Took it to my friend shop, he tried to hook up the Shop's AUTEL scanner to calibrate. It started the calibration progress (lowering), then upon trying to raise it, it failed. At that point, the car stuck with code 1437 (since the calibration was not complete). So I know for sure that: 1. Communication to the control module is working. Not sure what's going on or what else to do. Durametric is basically helpless since I couldn't even get past the first stage. Please advise, Kev
  6. Hello, is there any update to the above issue? I'm stuck with the same error on my 02 CS. Thanks, Kev
