Marc Gelefsky
Everything posted by Marc Gelefsky
  1. Thanks Loren! I cleared them and the 907 has not returned. Unfortunately the 1772 has returned and seems to give the Faulty/workshop error when the outside temps are cooler. I dont suspect any bettery issues.
  2. My 04 Cayenne S is throwing 2 codes, no CEL. DME: 907 Load management operat. on vehicle electrical sys./DME control module Present No other codes or engine miss, slight tick from engine?? Coils? Other one is the Air suspension, I get the "Faulty/workshop message" on startup now and than. Code is: 1772 Signal lead for pressure sensor Pretty sure I can solve this with the VW Compressor rebuild kit.
  3. Thanks Loren, Just ordered a set...since I was ordering a new ignition switch for the 996 I just them em on the order :)
  4. Hi All, I have a radar receiver that I need to remove for repair, It is behind the center grill, what is the best way to get to it? The grill does not appear to come out the front. Thanks! Marc
  5. Thanks for the reply Odix, but the problem is in the shifter, the Tip buttons on the wheel work fine. I suspect it's a similar issue. Perhaps something spilled into the console by the shifter. Best, Marc
  6. Hi all, Issue with my new to me 04 Cayenne S Tip, shifts fine no problem in automatic mode, works perfect in manual mode using the steerting wheel controls but if you want to use the shifter it will only downhift if you push hard, it will not upshift. Scanned with duranatic and no codes. Some kind of bad microwitch? Thanks!!
  7. I agree, matt look is great! In fact the gloss bezel is only thing holding me back from this kit - If the bezel came in semi-matt look (for black interior) then I would buy this kit in a second! Trieu if you're reading..... ;) Guys, I used Trieu's trimplate and painted it with Rustoleam's Textured Paint For Plastic in Black, came out PERFECT! Just out of curiosity... did you have to prime it or clean it with anything first before you sprayed the rustoleam? I just gave it a light sand to make sure the paint stuck, wiped it down and painted. 2 coats and spary from at least 12 inches away to get the best match.
  8. +1 to that! I don't even think we have Rustoleum here in Australia. The thing that appeals to me about Trieullionaire's kits is that they come complete: all the hardware, fascias and trim pieces, and odds and ends required to do a professional install. Even if I could find an equivalent brand of spray paint, I haven't the faintest idea about painting and don't want to screw it up :) Trust me when I tell you guys that ANYONE can paint this.. really, I am no painter and look how great mine looks.
  9. I agree, matt look is great! In fact the gloss bezel is only thing holding me back from this kit - If the bezel came in semi-matt look (for black interior) then I would buy this kit in a second! Trieu if you're reading..... ;) Guys, I used Trieu's trimplate and painted it with Rustoleam's Textured Paint For Plastic in Black, came out PERFECT!
  10. Please give our search a try... http://www.renntech.org/forums/index.php?s...st&p=112722 I did try but somehow missed this, Thanks Loren!!!
  11. Anyone know what Audi auto dim mirrors are interchangeable with the 996? Thanks!
  12. hello how did you have put this please the old iron is attached with the cup holder I am sorry, I unsure what you are asking, The mounting does not stop the cup holder from working, The cage mounts below, I used double sided tape to mount the trim.
  13. The leather looks pretty cool!
  14. I have the Avic Z1 in my 02 w/Bose, It did sound great but I noticed that the sound quality is a bit muddy now, I have not checked the wiring but could a bad ground cause this??? Thanks, Marc
  15. I just did the GT3 style Aerorkit II on my Coupe. Mike Shaw flat out told me I would not be happy with a fiberglass bumper so I used a factory Aero front bumper and side skirts with Mike's rear wing, The quality of MASHAWS rear wing is first rate.
  16. CDR-220s have a low power line out, so they're barely going to drive a speaker if they're not amped. All CDR-220 systems had an amp in the trunk. This guy intalled it in a MB500E so who knows. I'm sure he fried somthing.
  17. Hi all, Is there a need to change to CDR-220 internal settings when going between Bose or non amplified car? Any output setting since "line outs" are not used. I sold my old CDR-220 to someone and they claim it sounds tinny but this radio was perfect in my car. Thanks!
  18. Nope, you just need to make sure the wire that controls that is not connected, there are instructions on this site.
  19. Hi all, I refinished my trim plate to match the textured plastic on the dash in my 02 996, It came out great! Looks as close to factory as I think we can get, Now I wish I could get rid of the "Pioneer" wording on the radio.
  20. Luis, My 02 works perfect with Bose amp and speakers. The wiring should be the same regardless of Bose or non Bose I am told. Best, Marc
  21. The cupholder can be removed. With the kits faceplate the cupholder in the 02+ 996 can be retained, I also have AVIC Z working fine with factory bose amp and speakers, I may paint the faceplate to match the dash or perhaps Arctic silver. my car is a MY02 996 Coupe (NON -MOST)
  22. I picked up an 03S Muffler and want to put it on my 01S, how hard is it to swap the exhaust? Can I do this myself? I am fairly competent! :) Thanks, Marc
