Pkcayenne
    Miami florida
    2004 cayenne turbo
1,220 profile views
Pkcayenne's Achievements
  1. Hi all my next challenge is my 04CTT, the below isn’t working turn signal stalk lights stalk horn tiptronic volume for radio selecting any menus on the dash electric adjustment for steering wheel any ideas relay of something else appreciated,
  2. Hi all I’ve been fighting with the cayenne again let’s me put the key in and turn it then I get steering fault as attached any ideas of a way around this or a reset thanks car won’t start
  3. Hi more like 8 I drilled them out and replaced with screws did all the work twice with the 30$ kit and neither time has it worked the cable gets twisted up around the spindle let me know what success I have because both windows driver and passenger front are shot
  4. Hi stupid question is the can box rectangular which would connect into the buttons on the steering wheel ? If this has gone bad on the kenwood aftermarket would it kiss turn signals and wiper functions also
  5. Hi any resolution with this I have the same lights and buttons flashing now nothing no turn signal wipers or volume for radio
  6. Hi I have an aftermarket connected has been good for the last few years. When I disconnect the fuse to the stereo all goes off, any idea where the gateway computer is ? Or if I can isolate the can issue
  7. Hi cayenne 04 CTT weirdness the below list of functions was intermittent now nothing works buttons on steering wheel tiptromic button on steering wheel wipers cruise control pin out adjustment all functionality on the steering wheel except it steers perfectly all fuses are good errors as attached any ideas was intermittent
  8. Did it fix this I have the same problem
  9. Hi I've patched mine so much it's a 100$ cable I'm ordering it because it's ongoing.
  10. Must be a small hole I've been driving mine for months with no problems I'm ordering a new cable this week
  11. Hi just had to replace my front drivers side air bag and reused the original sensor now I get air suspension workshop fault checked the height for the front and each side is a little off by a few mm and the back is a little higher, any idea how to reset this error
  12. Thanks will buy a new hose 1st the booster vacumn pump is constantly running
  13. Can someone check if there vacuum pump ticks ?
  14. Hi number 19 the pump is working but a tick tick tick when running any ideas ?
