Zookie
Everything posted by Zookie
  1. Loren does this Include the Sway Bars?
  2. My Light does not Work, Yesteday i had it out but i could not get the Green Peice off to change the Light Bulb. How do you remove the Green Thing?
  3. Thanks Loren... i knew i was not Crazy!!! The last Version was much much better and organized to use... In this version all thw Modifications are mixed up unlike that last one where it was in Sections... i hope the new release is similar to the last one...
  4. dint help... I want to change the Display Pic that shows up on the MAIN Page... When i go to Images and Edit there is no Option to select for it to show up at MAIN Page Image... Maybe you can do it for me... i want the First Image uploaded April 11, 2010 - 04:20 PM to show up as my MAIN Page Image...
  5. The only Edit Button on the "MAIN" Page next to the Image is to Edit The Information... not the MAIN Display Picture itself, that shows up on the Main Page...
  6. How do i change the Picture i want to show up on the Main page of my Registry?
  7. hey did you figure this out? I have the EXACT same problem... was it the Relay?
  8. Read the thread, before posting... http://www.e-partssales.com/miva//merchant..._Code=POTE996CM
  9. Im sorry but the information you have provided is incorrect... Part number 000.044.901.21 was Released in Aug 2008 and the Maps are from 08/2007... There are no Updated Map Packs since then, and the PCM 2.0 has been completely phased out. That means there will be no more Map Updates... no 2009 Version....
  10. 408 OPTIONS!???? WOWZERS
  11. Yes i got a set from Suncoast http://e-partssales.com/Merchant2/merchant..._Code=POTE996CM It was Released 26/06/08... 8 CD's, you just insert any CD and it Updates your Firmware... Covers Canada, USA, Hawaii, Mexico, Puerto Rico, and Brazil... The Maps are Up-To-Date to 08/2007
  12. Any idea whats the Option Alpha/Number for the Instrument Surround in LEATHER (2.4a) in a 996 is?
  13. Okay as i can see the Fabspeed and Schnell are the same. Which ones better? Also is the EVOMS CAI better than this, what do you guys Recommend?
