Rogerio Almeida
Everything posted by Rogerio Almeida
  1. Looking to discover what happened with my 2001 top I opened the gearbox that makes the top up and down to check if the gears are ok ....and they are... (found out latter that the cable was he problem) The problem is how to set the gears position again, to allow the electric switch that is coupled with it to be turned on and off in the right moment. If someone had the same bad idea to open unnecessarily and was able to assemble again, please help. Thanks in advance
  2. Hi I had a problem in top and disassembled the gerbox that has the electric switch I discovered that there is no problem with it . Now I have problems to adjust the gears to touch the switch in the right position . Does anyone went through the same problem, or have any instructions how to set the correct gears position? Thanks
  3. Bingo! Thank You !!!!!!
  4. Is it Be 4462 ( I believe) CDR 220 It is from a 2000 Boxster Thanks
  5. Help needed! Radio locked Number: Y5026493 Please can you get the code to unlock it? Thanks
