tt2001
Everything posted by tt2001
  1. Do you have the diagram for the nob remove. Thanks million.
  2. That'l help. THANKS! I think I need check the center pivot. My next question is how to open the shift cover.
  3. Hi Loren, Thank you. It's the shift lever, loose when move between (D) and (M).
  4. Problem on my '99 Carrera Tiptronic. The shift between D - M becomes very loose , I turn into accidentaly shift it when I drive. Any idea? How to fix it. Thansk.
  5. Cobra, I has the same problem just like yours.
  6. Thank you Dean. I will try to order a MAF today. Tommy
  7. Where is EVAP canister located? No after market filer nor intake system. Fuel filter just changed within 30days. Do you have the '99 996 intake diagram for my tracing? Thank you much. Tommy
  8. Loren, The CEL on again after one month -1000M , OBDII read as P1128 P1125 and P1130 I reset them , and not come back for 20M drove. Any idea? Thanks
  9. Loren, After cleaned those old oxygen sensors by wire brush and put them back, the CEL not coming back so far. Can you kindly email me the MY99 in case I have wrong parts again. Thanks,
  10. Loren, After changed all four O2 sensors , the CEL still came back on after 10min.( I only disconnected the battery to reset it) That's scanner reading: P1115 P1119 P1117 P1121 I check the new parts number was different than the old one. Ahead of catalytic 993.606118.01 (OLD) 996.606.161.178.01 (NEW, Black color) After Catalytic 993.606.128.01(OLD) 996.606.161.168.01 (NEW, Blue color) There's only one way (direction) the each connector can be plug in. 1. Did I use the wrong parts? 2. Do I have to reset it by OBD-2 Scanner instead disconnect battery? Thank you, Tommy
  11. Noor, You're exactly right. The light on again today, now I think I need to look into the O2 issue. Thank you. Tommy
  12. Dear all, Finally my CE light off after I tighten the coolant reservoir cap. Any idea? Anyway, I'm so happy for the problem solved. Thanks a lot everyone .
  13. Periokid, Thanks a lot ! I'll check it first.
  14. Loren, Thanks again. you always so helpful. Can I still drive the car? it's nothing different, so far.
  15. '99 996 , 53500miles I had my check engine light on today, unexpectedly. It remains on while driving, I checked user manual, it not talk too much of it. Where I should start? Thanks,
  16. :clapping: I came back remove the door panel again to check, you know what, the microswitch connecting was loose because I not arranged the wire well at first time so a tension pull off the plug. Thank you guys.
  17. Tool Pants, You must be right, I might forgot one wire connection. Thanks a lot. TT2001
  18. Loren, Thank you, I will check them. Best regards,
  19. '99 Carrera. 53k miles After remove the door panel to fix the window and put it back , now my car can not be locking . A double horn signal during locking by remote control and key. Is the car needs to reset the computer after removed the all connectors on the door? Is there any way I lock the car before I visit the deal. Help please. Thanks.
  20. My car recently has odd smell like shoes polish kind. I changed the pollen filter but the smell still comes from the vent , but if I turn on the air condition or close blower the smell stop. Anyone know what's wrong? Thank you.
