Domino_S
About Domino_S
  • Birthday 07/25/1991
    Latvia
    2003 Cayenne S 4.5
  • Future cars
    Panamera Turbo S
    2003 Boxster S 3.2
837 profile views
Domino_S's Achievements
  1. Good time of the day! Does anyone installed aftermarket head unit in 1st gen Cayenne with working steering controls? Perfect if it's Pioneer (like mine). I have AVH-X8700BT sitting on a shelf. I know it has a learning function for steering controls, and plugs in by 3,5mm jack. All I need is wiring diagram for original control bus. Can't seem to find anywhere. I will be gutting all BOSE system, cause it's prehistoric piece of hardware. TIA.
  2. Do you still have a ink to the Cayenne service manual.  Also need the Panamerra service manual. Thanks
    My email is vixentd@gmail.com
  3. Wires all good. Pump works well, when I connected it to battery. Could it be some errors on heating system after starting engine without coolant? I had to check if it starts (for 5 seconds max.), when I bolted new engine on the place, before take it all back together.
  4. Yes I did the swap by myself, took me few days. Engine was from another CS that was in accident - rear of the car was badly damaged. And today I found out, that heating comes back after engine is at working temperature and keeping rpm @ 3000. So I guess, main water pump gets enough power then to push antifreeze around the big circle of heating unit. And aux water pump doesn't make any sound, but it did before swap. So I think it could be some wiring problems of this pump, because engine swapping was messy job and I could have pulled some wires accidentally. I will take a look this weekend.
  5. Last week I had to change my 2003 CS engine to 2006 CS engine, due to severe engine scoring in 5;6;7 cylinder. Everything now works fine, but no heating even when I turn up to HI. Does anybody had this problem?
  6. Here's digital version, of it. I guess it's the "original", it has over 9k pages, but not in pdf.
  7. I've already did it that way. Nothing happens. When I start the car, those 3 LEDs on console flash once, if car is not running, but ignition is ON, only middle LED flashes couple of times when switching. But if car is running, in neutral and brake applied, no LEDs flashing and no sounds from switching under the car. Fuses all good.
  8. Hello, Does someone had problems with switching low/high range gears? When I try to switch low gears when car is running (key position 2) - nothing happens, but when ignition is in position 1 (car not running) and I try to switch in low gears - middle red LED flashing on knob, BUT still nothing happens. When I go into OBC menu >veh.info it says Reduction OFF & Locking OFF. Btw, diagnostic tool not giving anything. If someone had this probem solved, please enlighten me!
