Gonzales
    Poland
    Cayenne turbo 500km, bmw 850ci,bmw z3 coupe,bmw 535i
704 profile views
Gonzales's Achievements
  1. @lewisweller Did it helped with your ac? Wysłane z mojego D6503 przy użyciu Tapatalka
  2. At 200k km. Both pumps. One after the other. Wysłane z mojego D6503 przy użyciu Tapatalka
  3. My ac just stopped working today. If I find sth. let you know. Wysłane z mojego D6503 przy użyciu Tapatalka
  4. I hale a problem with durametric That I can't read faults but I can read actual values. Have you any ideas ? Ctt 2004. Wysłane z mojego D6503 przy użyciu Tapatalka
  5. @bluetoff. How many years? Wysłane z mojego D6503 przy użyciu Tapatalka
  6. Do not install lpg. I have stag with hana (Best I suppose) injectors. After 2 years my problems started. Burnt valve... This car is not good for lpg. I have lpg in bmw 535 from 1991 after 10 years no problems at all Wysłane z mojego D6503 przy użyciu Tapatalka
  7. Transmission has main lockup gear burnt. I did full service of tranny and converter. I already bought new 11 liters of atf. Now it is time to put it in. BTW I have possibility to do shaft bearing and I will also decat the pig. My tranny guy said that tranny failed because of heavy trailer (2 horses) I used to pull with ctt. He says this is not a car for such purpose. Wysłane z mojego D6503 przy użyciu Tapatalka
  8. Managed to take out trans - DIY. I will post when have time to open it. Wysłane z iPhone za pomocą Tapatalk
  9. Finally managed to pull out trans - DIY. Nightmare but I did it. Trans is damaged for sure. Will post as soon as I have time to open it. Wysłane z iPhone za pomocą Tapatalk
  10. Idle problem solved. 5000km Spark plug with 0 (zero) gap. But now tranny failed. 721 code. Only reverse and 5th gear forward.
  11. Thanx a lot for reply. Do you know by chance part nr?
  12. Hi,I have exactly the same issue. Did you solve the problem? I did all the checkings, tested it with durametric, changed fluid and nothing. Dont want to throw out transmission which is maybe good. I'm out of ideas, valve body - maybe but until this happened no issues with trans at all.
  13. Hi,I have exactly the same issue. Did you solve the problem? I did all the checkings, tested it with durametric, changed fluid and nothing. Dont want to throw out transmission which is maybe good. I'm out of ideas, valve body - maybe but until this happened no issues with trans at all.
