rockhouse66
About rockhouse66
    Western NC
    2004 996 Cabrio 6-speed
1,372 profile views
rockhouse66's Achievements
  1. Agree - could be SAI pump. Mine got quite noisy and I found some info online about how to take it apart and relube at least the outer bearing. Helped a lot.
  2. I had oil residue in that area above the spark plugs and on top of the right rear cylinder head. That corrugated line, It. 4 in the diagram posted, apparently had some minute cracks in it and was seeping. I replaced that line and solved the problem. Admittedly, I replaced the AOS at the same time so can't say for sure it was just the oil line but it had to contribute for the oil to get to that location.
  3. Translation - it is buried and awkward to access.
  4. I can tell you that my 996.2 had those exact symptoms and no CEL. Replacing the vent valve at the filler fixed the problem. I can't say how your car differs from mine, except that I would rather have yours!
  5. Keep an eye on the O2 sensor cables when dropping the engine down to be sure they don't reach their limit of travel.
  6. I have a similar situation as Mr. Whitney. My 2004 996 originally sold in Canada has the fog lights on all the time. I removed the relay to kill them (permanently) but would like to return them to switchable. There is actually a wire cut at the headlight switch that I suspect is the fog light wire.
  7. As you probably found, actually replacing the IMSB is easier than all of the rest of the work to get to that point. I think you are home free.
  8. My spoiler is a factory XAG option code, described simply as "Carrera Spoiler" on the build sheet. Looks like this:
  9. I don't mean to start an argument with this, but just adding some info. My '04 Cab has the optional factory side skirts and rear wing. I have studied the 2004 Cab option list and apparently no front spoiler was available so this is as close as the original purchaser could come to buying an "aerokit" for this car. Porsche must have considered this combination of parts OK w/o a front spoiler. I also question whether the aero imbalance issue is relevant at normal speeds and might only come into play at Autobahn speeds (as in 100 MPH plus)?
  10. Is the system the same as on a 996? If so, the most common cause seems to be the vent valve contraption just below the filler neck. I had the same symptom and replacing this vent valve fixed my 2004 996. Mine didn't throw a CEL though, just wouldn't start after fill up.
  11. Yeah, me too! The car is still on the lift and messing around at the front I think the RF wheel bearing needs to be replaced. Sounds scratchy when spun (and no, it isn't dragging on the rotor - this is with caliper/rotor removed). So, I get to use my tools again. And this should be a piece of cake without the drive shaft to deal with.?
  12. OK, I am all done except for final torque on the axle nut. The tools worked fine. The job, as a whole, was a physically tough PIA for me. Working the axle shafts out and back in, dealing with the hub removal from the bearing, etc. This is working alone but with a lift. If this really is a 2 hr. per side labor charge at the Porsche dealer, I would recommend just paying them to do it. I would love to watch this job done in 2 hrs. per side. BTW - would it be good practice to put some anti-seize on the axle threads or just leave it dry? 340 ft-lbs seems like it would like some lube.
  13. Yes. Works fine from the switch. Windows go up after about a 2 second delay.
  14. Excuse my impatience, but no thoughts on the fix for this? Or maybe my car never had this feature (though it appears in the owners manual)?
  15. It would be really convenient to be able to exit the car with the top down and close it up completely while standing at the door. I would like to make it functional if I can figure out where to start. I suspect it could be something in the door lock itself, or maybe in the top latch or even the dash button area.....?????
