2000gt
About 2000gt
  • Birthday 09/01/1990
    ontario canada
    996TT
    330I ZHP
    996TT
    E55 AMG
    B7 S4
    06 STI
    S14 240SX
792 profile views
2000gt's Achievements
  1. Thanks for the tips guys I'll give it a try tmro and see what happens. After refilling the unit in the back. Do I need to anything else? Sent from my Pixel 2 using Tapatalk
  2. Hello everyone. Came on to here to see what you guys think of the situation I have going on. I have read that if I have fluid migration to the front that means I need a new slave... And if I have a stiff clutch pedal I need accumulator... Now my problem is I have non of the problems but I have a leak from where the clutch slave/accumulator is located. The only area I see and feel has a leak is the high pressure supply line from the hydraulic pump. Fluid level in frunk is within spec with now dampnes and in the back it's below the low level on cold/hot. Makes sense as I have had a big leak.. car has been parked for 6months now. Everything feels perfect as far as clutch engagement goes and pedal feel. Car does have newer accumulator as it's 27mm. Not sure about the slave.. I was thinking of taking the accumulator off and working on the supply line. Do you guys suggest anything else I should do or anywhere else to inspect? Sent from my Pixel 2 using Tapatalk
  3. That looks good in red! Very capable Cayman. Sent from my Pixel 2 using Tapatalk
  4. You gotta move the oil filter housing and you'll be able to reach it. Sent from my iPhone using Tapatalk
  5. I mean I switched it with another working maf from a different car.. This car has the oxygen sensor extensions instead of sensors for the after cats Sent from my Nexus 6P using Tapatalk
  6. Hi everyone. I was able to scan the car and get the following codes. P0056 P0030 P0050 P0161 All are for 02 sensors. The car currently only has 2 02 sensors. Would that mean I now need 02 sensors? I have switched the MAF around and it didn't change anything,borrowed a friend's MAF. Car had a buff of black smoke when revved hard and you can easily smell raw fuel-running rich. Sent from my Nexus 6P using Tapatalk
  7. Hi guys! I got a 01 996T 6speed that I am having some problems with and would like the help of fellow P-car owners cars has been sitting for a year. as of late I started working on it. have changed the following parts: -fuel filter -fuel pump -spark plugs -air filter -new gas -coolant flush car did not want to start at first but after changing the plugs it, it started fine. I dont get any codes. It does run ok on idle put once you apply gas it starts to choke and backfire,even though it will rev to redline no problem. I ran it with and without the MAF on but nothing changed. I took the exhaust off to check for clogged cats but everything was fine. It would still choke and backfire. I also have more than half tank of gas but still read below empty on the fuel gauge. my next step was to check injectors and check for vacuum leaks or check for fuel pressure... So has anyone experienced these symtoms before? What else should i test? thanks for input towards this problem in advance.
