SabaDabaDoo
    AZ
1,326 profile views
SabaDabaDoo's Achievements
  1. 1980 Targa: Checked the fuse (#4) and the bulbs: all good. Installed a different turn signal stalk: no resolution. Help Sent from my iPhone using Tapatalk
  2. It is time to restore the tired interior of Smokey (1980 Targa). Any fair and respectable shop in Southwestern states? Preferably AZ. Sent from my iPhone using Tapatalk
  3. I wonder if at higher speeds, the asymmetrical design of the spokes creates a “drag” on one side of the car! Vs Sent from my iPhone using Tapatalk
  4. Do you guys recommend graphite or silicon vs oil based lubricant? vs a water repellent like WD40? Thanks. Sent from my iPhone using Tapatalk
  5. Thank you Loren, and as expected : both horns were dead ( along with the first used but genuine replacement). Had to get a new aftermarket . Sent from my iPhone using Tapatalk
  6. Thank you for the great step by step instructions. How to test the horns themselves vs the wiring? Sent from my iPhone using Tapatalk
  7. A period after struggling with steering wheel screws, and doing the described fix, horn stopped working completely, blown fuse was found and replaced, still no horn, relay removed and tested ( despite hearing the clicking) all good, now the only logical thing left is the two horns themselves, problem is I have the 996 with the Aero kit, is removing the bumper as straight forward as the regular one? Sent from my iPhone using Tapatalk
  8. Thank you , very helpful. Sent from my iPhone using Tapatalk
  9. This just started last week for no apparent reason, it is embarrassing when I get dirty looks from other motorists! Cause? Solution? Sent from my iPhone using Tapatalk
  10. Will do, thx Sent from my iPhone using Tapatalk
  11. My parking spot for the 996 requires a slow sharp left hand turn, and on occasion I hear a groaning noise from the driver's side front end of the car (that is different from the usual steering pump noise when making sharp turns). what do I need to look for before things get worse ? Sent from my iPhone using Tapatalk
  12. Thank you so much I pulled out the cassette holder and was able to fish out that phone plug, then used tiny alligator clamps to access the switched and ground wires...worked like a charm. Sent from my iPhone using Tapatalk
  13. To add a twist to things: I have a dash cam that is powered by the usual 5v usb that plugs into the 12v socket. The problem here is if I am to hardwire it into the switched plug you kindly referred to, how to circumvent the difference in voltage? Sent from my iPhone using Tapatalk
  14. Could anybody point me to the article on how to access a switched wire to power my radar detector ?( or how to change the cigarette lighter into switched power?) Thanks Sent from my iPhone using Tapatalk
