dinosaurking
Everything posted by dinosaurking
  1. Thanks for the reply. Haven't tried cleaning idle stabilizer yet - will give it a go. Tried a new fob battery but no improvement. I had the codes read and are below. I'm thinking fuel pump, fuel pump relay or O2 sensor? (But it didn't give a sensor code?) Many thanks.
  2. Suddenly after 4 years of owning my 1999 2.5 - things have all started to go wrong at once... I'm wondering if any of the issues could be linked at all? Any help would be most appreciated. Many thanks. - ABS Traction control lights on. (ABS & TC not working). When car is hot (after 40miles +) It won't maintain a steady speed. It feels like it's running out of fuel and judders/misfires serverly – you have to back off or put more power on to stop this. (It accelerates fine though.) Then, when at a stop it won't idle and the revs will be hunting and it stalls. After the car has cooled down (ie next day) it still has the issue but only for a few minutes then it is completely fine again. - Remote key fob not working. - Spoiler light illuminates after dropping below 50mph. Spoiler is down though when car has been stopped. - Air-con not working (Was re-gased and worked for a bit) - Possibly running rich. (high fuel consumption and black around/on exhaust tip) Recent parts fitted. (symptoms presents before and after.) Service (Oil, plugs, air and fuel filter) Bosch MAF (same part number as previous one fitted) Air/Oil separator Drivers side radiator Water pump and aux drive belt Low temperature thermostat Exhaust U bend pipes Front 'coffin' arms Brake pedal switch Battery
