  1. I think you will need to change the hubs too if you put GT3 brakes on the car. Some folks that just want red calipers just buy the one for a Boxster S - they are the same caliper as the 996 -- just red.
  2. Hi, I also did not get the code card with my used Porsche and the battery went dead over winter. Next year battery maintainer! Any help would be appreciated. It is a 2000 Carrera CDR-220 Type: 4462 Ser: y5040879 24/99 Thanks. Try 0857 or 0855 Tried 0855, 0857, 0856 and 0858 none of them worked but I will cycle through them a couple of times to be sure....... lots of waiting. Thanks for the effort. 0859 worked Thanks. Hi Iam from germany...i bring a boxter from miami to Munich(Germany9 but i lost the CODE from the Radio Model CR 210 Art. R3297 SerN. V5008018 Please HELP ME......Thank you greeting from Germany...sorry my english is not sooooo good. Try 1143 or 1141
  3. The only listing I see for RoW cars is for the rear bumper cover. It is: 987.505.993.00
  4. Do a search here for the reset procedure (which involves reversing the battery for a few seconds). If that doesn't work then you likely need a new remote (check with Sunset Imports for the best price I've seen).
  5. :welcome: Search is your friend. Please give it a try. Many discussions here on swapping motors.
  6. MSRP $18.71 from your dealer if you would like to scan one for us...
  7. 97_993TT_radio.pdf
  8. http://www.renntech.org/forums/index.php?s...ost&p=20176
  9. You are lucky if the fronts don't rub now - so I would not mess with them. The rears may need a trial fit for the same reason - if they rub drop back to a 285.
  10. That is why I posted a pic ;)
  11. :welcome: Please do a search here for P1125. This has been covered many many times.
  12. VW special tool 3217
  13. Under the dash to the left of the steering wheel (all Porsche's are the same).
  14. No Idle Control Valve on egas cars. It would not hurt to clean the throttle body but that is not likely the starting problem. What did you use to check the fault codes?
  15. The sensors are just wires - that when worn through trigger the light. So, if you want to bypass them you will need a wire jumper at each wheel -- or buy new sensors and tie-wrap them away from any moving parts.
  16. Check to make sure you don't have a pebble ot two caught between the brake disc and the splash shield.
  17. It will be similar to the RoW030 install here.
  18. Try 3729 or 3727
  19. Get your fault codes read you could have pending codes. Have you checked your ignition switch?
  20. Try 0461 or 0459
  21. Yes, it sounds like the camshaft is out of timing.
  22. Um... I am not sure I remember. It may need a load for the high voltage.
  23. Um... DTC's not P-codes. DTC 12 = P0136, P0140, P0138 Oxygen Sensor After TWC, Bank 1 – Signal Implausible Oxygen Sensor After TWC, Bank 1 – Above Limit Oxygen Sensor After TWC, Bank 1 – Open Circuit Best check the wiring/O2 sensor for damage. DTC 322 = P1340 Timing Chain out of Position, Bank 1 – Below Lower Limit Timing Chain out of Position, Bank 1 – Above Upper Limit This fault can be stored only if the engine was disassembled and the allocation of the outlet camshaft with respect to the inlet camshaft was incorrectly set.
  24. Try 996.555.611.01.V01 That is the door handle in silver lacquer (V01 is the color code - which is required). Any good parts person should have caught that. Try the folks at Sunset Imports (Porsche Parts at Dealer Cost) - I'm sure they can find it and give you a better price.
  25. Where are you located? Perhaps another member can give you a hand.
