  1. :welcome: That is your clutch interlock switch. It is either poorly adjusted or needs to be replaced.
  2. Just remove the rear bumper and everything is accessible. It's pretty straight forward.
  3. Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  4. Thanks Loren. Unfortunately the numbers aren't working. I got the "code" sign, pressed the number in, then pressed the "up" arrow... and nothing..... just the "code" sign again. Any other words of wisdom? I appreciate your help so much. It's amazing how many people you've saved from car-silence!!! =) Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  5. Model Year 2005
  6. That is for Litronic/Bi-Xenon self leveling headlights.
  7. I think you have to fill out a form and have a Referee (smog Referee) verify that parts are not available. Also, I found this at the CA Bureau of Automotive Repair. "California law limits the amount of money required to be spent on repairs needed to pass a biennial Smog Check inspection to $450 minimum. If you have spent at least $450 on repairs at a Smog Check station and your vehicle continues to fail inspection, you may qualify for a Repair Cost Waiver. A Repair Cost Waiver postpones the certificate requirement and allows you to complete the vehicle registration renewal. The Repair Cost Waiver can only be issued by the State Referee. Please note that the repair cost limit only applies to the biennial Smog Check requirement and does not apply to the repair of tampered emission controls or repairs performed prior to inspection. A vehicle receiving a waiver must be fully repaired by the next Smog Check requirement. A waiver may only be issued once to an owner of a particular vehicle and may not be issued if a waiver was issued during the previous biennial inspection."
  8. Try 8469 or 8467
  9. Then I guess Porsche's parts list is wrong. Here are the part numbers and the codes signifying they are for the rear.
  10. Remove the front bumper - replace horn(s).
  11. Hmm... haven't heard that one. As long as your cap is 996.106.447.01 (or later) and it does not leak - you should be fine IMHO. I bought a new cap from Sunset Imports a couple months ago and it was $11.80.
  12. Just follow the instruction in the OBD II manual or the service manual. Might I ask why you are changing your DME?
  13. Is the a CR-21 or CR22? I have no idea if this will work for your radio... Try 8469 or 8467 Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  14. Since this is your site - I think you need to re-read the rules here about commercial posting. This topic is closed.
  15. Is the a CR-21 or CR22? I have no idea if this will work for your radio... Try 8469 or 8467
  16. Here is the picture that is in the parts list. There is also a "Operating Instructions Multimedia Interface" 997.044.901.74 that I assume is some sort of manual...
  17. 997.504.573.02 Left rear wheel liner (RS) 997.504.574.02 Right rear wheel liner (RS) You will also need the plastic nut 999.049.028.40 (sorry I can't remember if it is 1 or more). And, tapping screws 999.073.231.09
  18. Try 6803 or 6801
  19. Another possibility is a very erroneous reading from your MAF. Can you check your TRA, FRA, and MAF air flow readings? If not you may want to try a new MAF.
  20. P0446 (Porsche fault code 95) EVAP Canister Shutoff Valve (Function) - Below Lower Limit The task of the shutoff valve is to seal the purge air line to the EVAP canister during the fuel tank leak test (at startup). Potential causes: - Bad gas cap seal - Purge air line blocked. - Flow resistance of EVAP canister too high. More here
  21. CDR22 - is wired radio -- CDR-23 is MOST (fiber optic) based radio. Sorry, they are not interchangeable.
  22. http://www.renntech.org/forums/index.php?showtopic=19983
  23. You can only buy the two repair kits. 951.352.917.01 30 mm kit -- US MSRP $10.82 951.352.917.00 28 mm kit -- US MSRP $12.57
