  1. Start by checking fuses E9 and E10.
  2. Try 1529 or 1527
  3. Seems pretty odd unless it was over filled, or the cap was overtightened, or the reservoir somehow took a blow that damaged it. I would watch it daily for a week or two and see if you notice level change or other problems.
  4. My model year 1999 Carrerra came with 18" wheels. There was no restriction mentioned in any TSB. Carrera's before MY02 were not recommended to have the X74 suspension upgrade because the chassis was not strengthened like the MY02 and newer cars. Perhaps that is what you were thinking of.
  5. Start by getting the battery tested - regardless of age.
  6. Yes, if you disconnect the battery is does have to re-learn. Just drive it as you normally would - it may take 5 miles or so to re-learn.
  7. Could be just a bad sensor...
  8. Try 4658 or 4656
  9. I can make back to back to back dyno runs on my car with nothing changed and get more HP every time. See my blog entry here for my of my thoughts on product claims and dynos...
  10. Goo Gone will also remove wax - so after I use it I use a paint cleaner and then wax again.
  11. Hi, I am having the exact same problem with my Boxster and am hoping you have gotten to the bottom of it, so I can as well:) Any news and/or luck? Thanks in advance, Rob Please do a search here - this has been covered many many many times here.
  12. Try 3028 or 3026 hi loren neither of these worked, any ideas?? im really stuck Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  13. :welcome: http://www.renntech.org/forums/index.php?s...p;hl=fan++speed http://www.renntech.org/forums/index.php?s...p;hl=fan++speed http://www.renntech.org/forums/index.php?s...p;hl=fan++speed http://www.renntech.org/forums/index.php?s...p;hl=fan++speed and many more...
  14. Try 3028 or 3026
  15. http://autorepair.about.com/library/images/bl255a-lib.htm Try it with a regular Phillips first - but don't strip it out if is very tight. I can only remember having to use an impact driver on one car and it had a lot od rust and a lot of years.
  16. Try 8658 or 8656
  17. :welcome: There was no C4S in MY1999 (C4S started in MY02) - so perhaps your car is a C4? What are your fault code(s)?
  18. Try 1143 or 1141
  19. A bad ignition switch could cause a battery drain - if the wrong parts are shorted and always on.
  20. Psst... I am not a psychic ;) I need your serial number... Lost Radio Code - FAQ, PLEASE READ THIS FIRST oops serial 15062050 model BE 4462 Try 0020 or 0018 Neither of these worked, any more options? You didn't read this did you... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  21. I suggest you write down the fault codes before you reset them - in case the problem comes back. Most tools have a selection of "clear faults" or "reset faults".
  22. Thanks for the quick reply. I am not familiar with the CAN Bus? Is it something I can access and tap into? Where is it located? Some of the more sophisticated telemetry systems use the CAN bus - you can tap in at the cluster or the DME.
  23. What do you mean by exhaust? mufflers or cats? Changing the mufflers will not cause any faults or error messages. Changing the cats might.
