  1. http://www.renntech.org/forums/index.php?s...st&p=102491
  2. Loren
    GT3 RS
    997 GT3 RS has a single mass flywheel - some rattle is normal.
  3. Please do a search here - those codes have been covered many many times.
  4. If the car is sitting level when you fill it - then it can not be over filled because it will run out the fill hole.
  5. Correct. The C4S uses the sames M96 engine that the Boxster and Carrera use.
  6. If you mix the wrong two non-compatible coolants you can create a "jello" like substance.
  7. That was point before... you need a CAN based system on the newer cars.
  8. It is hard to tell what he means - when he says reflectors then it makes me think the inside piece.
  9. Removing the Amber on the Headlights
  10. Yes, depending on the tire manufacturer.
  11. Try 9027 or 9025
  12. The only thing you might need IPAS codes for would be changing the odometer - but if the odometer is over 52 miles then it can't be changed with a PST2 or PIWIS.
  13. Try 0210 or 0208
  14. Try 6439 or 6437
  15. B13 (blue connector) is the speedometer signal. Too my knowledge there are no optical connections on the instrument cluster - optical is only used for the audio system network (MOST).
  16. Please do a search here -- there are several current threads discussing this.
  17. Thanks for the quick reply. I am not familiar with the CAN Bus? Is it something I can access and tap into? Where is it located? Some of the more sophisticated telemetry systems use the CAN bus - you can tap in at the cluster or the DME. The cluster I assume you mean the instrument cluster? On the DME/ECU can you tell me what lead to tap into? Does it have some kind of identification? Do you know where I can get a swithced 12 volt as well? Thanks Some of the more sophisticated telemetry systems use the CAN bus - Do you have a system theat can pick up network (CAN) data?
  18. Try 5408 or 5406
  19. Try 5541 or 5539
  20. Sorry, not trying to confuse more. I meant reverse the engine - the pulleys face the rear on a Carrera and they face the front on a Boxster. Some folks don't realize that.
