  1. The latest US price list shows that number "99610614708 EQUALIZING TANK $274.55" PET does not.
  2. Please post your requests once - you already posted this in a different thread. Thank you.
  3. On a Boxster the muffler is not in the way - so it is much easier.
  4. IMHO that is way too much. Is your car under warranty - if so those cracked ignition coils should be replaced free. If it is not under warranty, all the coil packs should be replaced - there is a TSB on this.
  5. On a new cluster the answer is yes a dealer could set the correct mileage. The question is whether they are willing to program your car as a 996 (so they can code the cluster) and then change it back to 986 afterward.
  6. no clue, but Durametrics will clear the light. good luck. Can any OBD2 reader pull a Porsche fault code? Some yes - some no. Remember there are DME fault codes (which most readers can see) but there are also ABS, airbag, HVAC, instrument cluster, PSM, PCM, etc., etc. controllers that can also have fault codes.
  7. If you wanted to lower the car I would suggest the RoW C4S suspension. That way you get a Porsche tuned suspension and lowering.
  8. Each code is specific to your serial number. It would be pure luck if any of the other codes here worked for your radio. Try 8262 or 8260
  9. +remove +console +remove +cluster +remove +trim
  10. Please post your request in the Lost Radio thread.
  11. Yes, fan 1 is the front left and fan 2 is front right. and yes, the ballast can be changed by itself.
  12. Front or rear? or both? Please do a search for this - all has been covered several times.
  13. Get the fault code as it will tell you exactly which buckle (or other part) is causing the light.
  14. Chances are you have a bad ballast, stuck relay, or bad fan.
  15. Chuck, Same exact symptoms on my 996 C2 last year. It was the water pump. Phillipj I think Chuck's point is that is is more often than not a hose on a 996TT - after all it is a very different engine.
  16. Yes, but the part number should end in D05 which is the color code - granite grey
  17. Sorry, you can only get PCM codes from a dealer.
  18. In the past they have come out in late June early July.
  19. There should be an option list sticker on the underside of the front trunk. Write the numbers down then look them up on the option code lookup tables here. If you don't see option 030 (sport suspension) then you have a stock suspension. Loren, Do you know if all 2002 996 C4S's come with the M030 suspension? I checked my option code sticker and M030 isn't listed. Thanks All US C4S came with US Sport Suspension.
  20. What tool did you use? Is it capable of viewing pending faults?
  21. Hi everyone, newbie to the forum. 1st Porsche also, a 04' cs. I just purchased this vehicle on an off lease. I had one of the dealers pull all the records for me and it looks like all the recall stuff had been done. I am experiencing the same issue with a rough idle and only when it's hot. After a night of cool down, it runs fine. I was wondering if your porblem was ever resolved and with what. I get a CEL and then it goes away. I know that I need to pull the code and should have the DuraMetric tool some time next week. Just lookin' for some insight. Any help would be greatly appreciated. Thank you. Without the code(s) everything is just a wild guess.
  22. Replacing the Gas Door Actuator
  23. Yes, you need the fault code(s) to pinpoint the problem.
