  1. Try 0951 or 0949
  2. Yes, as long as they use the tips from the older mufflers.
  3. It should only come on for a few seconds when you turn the key on.
  4. The DME would need to be reprogrammed to that countries standards, cats would likely need to be changed too. He should check the local laws because in some cases you can get a deferral.
  5. Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  6. Try 8846 or 8844
  7. Please do a search here - this topics has been covered many many many times here.
  8. For 9x7 series cars the 6 ranges are: Range 1: 7300-7500 RPM Range 2: 7500-7700 RPM Range 3: 7700-7900 RPM Range 4: 7900-8400 RPM Range 5: 8400-9500 RPM Range 6: 9500-11000 RPM You really don't need to worry about anything other than ranges 4 to 6.
  9. Did you miss this part? "14 mm and the pitch is 1.5"
  10. Item 5 is 999.631.140.90 6W bulb -- US MSRP $14.18 each
  11. Which item number please?
  12. If it comes and goes it is not the fuse - if it always off then it could be a fuse.
  13. 999.631.032.90 5W bulb -- US MSRP $1.10 each
  14. Most of these problems with CDR-23 and BOSe turn out to be bad amps.
  15. Hello Loren, Can u please help me how to remove the passenger airbag cover , is not in my notes! :huh: That (and the precautions) are covered in the service manual - Section 69 68 19 Removing and installing the passenger's airbag unit
  16. The Porsche exchange parts list shows both engines for MY06 - so I think you likely get a 3.2.
  17. Try 5498 or 5496
  18. Your car, VIN and all existing keys are required to program a new key.
  19. 480 is the option code for 6 speed transmission 495 is the option code for Carrera S The list calls out Canada specific parts with the (CDN) in the model column. If a gauge is non-country specfic then it is the same for US and Canada.
  20. 997.641.503.00 Sensor -- US MSRP $21.95
  21. Sounds like another cracked coolant tank to me...
  22. Try 2893 or 2891
  23. If you are noticing a power loss at higher RPM then you likely have a bad MAF. Try unplugging the MAF and driving the car - if it drives the same and has high RPM power loss - then you need a new MAF.
