  1. Try 5498 or 5496
  2. Your car, VIN and all existing keys are required to program a new key.
  3. 480 is the option code for 6 speed transmission 495 is the option code for Carrera S The list calls out Canada specific parts with the (CDN) in the model column. If a gauge is non-country specfic then it is the same for US and Canada.
  4. 997.641.503.00 Sensor -- US MSRP $21.95
  5. Sounds like another cracked coolant tank to me...
  6. Try 2893 or 2891
  7. If you are noticing a power loss at higher RPM then you likely have a bad MAF. Try unplugging the MAF and driving the car - if it drives the same and has high RPM power loss - then you need a new MAF.
  8. Since you don't have a second key perhaps now would be a good time to buy one.
  9. If you remove the seat -- Do not put the key in the ignition while doing this or you will get an airbag light. The airbag circuit is activated when the key is put into the ignition (even in the off state). You are looking for water damage to the central locking/alarm control box.
  10. The lists for a MY03 Boxster are here
  11. Correct, the coupe, and cabriolet (and Targa) all get different RTS kits.
  12. The first question is - is that really where the oil is coming from? I suggest you clean it off and then look again after a drive and make sure that is the source.
  13. http://www.renntech.org/forums/index.php?s...ost&p=13256
  14. Usually a bad ignition switch gives many electrical anomalies.
  15. Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  16. Yes, BMC will improve engine sound some. No way any air filter gives 8 to 10 HP - sorry that is just marketing hype.
  17. Had one - sent it back after numerous CELs. A good BMC air filter works just as well (IMHO).
  18. I've done it with a couple of screwdrivers - be careful to not scratch the paint.
  19. Would you know of a place that sells porsche parts online? So i can hunt for the best price if i can not find anyone to weld the casting back together? Thanks again man. Where are you located?
  20. Rennlist is subscription. RennTech.org is supported by donations. Certainly you mean RennTech.org ;)
  21. so then im screwed. Would a porsche dealer try to fix that by welding it or would they send it out? And if they have to repair it by getting a new one, how much would the part cost and the labor? Thanks again. That will depend on the dealer. Prices vary everywhere... get a written quote. I would suggest a really good independent shop.
  22. It is questionable whether the key was ever programmed to the car. Was there a tag with the key with a 24 digit code?
