  1. Changing from non-OBC to OBC on any cluster is easy with a PST2 or PIWIS. If the car did not have OBC then you need to wire the 4th stalk or wire in a dash switch. On MY00 and older Boxsters when you turned OBC on in the cluster you immediately saw the outside temperature displayed. In MY01 and newer Boxsters when you turn on OBC in the cluster you see no change until the stalk (or switch) is added.
  2. Pretty much the same - just larger.
  3. Front Rear
  4. Yes, they should as long as the 996 is a coupe. if so part number pretty please! 996.803.033.90.N13 Left seat belt in Guards Red 996.803.034.90.N13 Right seat belt in Guards Red
  5. Try 8350 or 8348
  6. Yes, if you have both clusters see if they both act the same.
  7. Try 1051 or 1049
  8. From the Porsche 2001 996TT Service Technik Book: "Fuel Cooler In order to maintain a low fuel temperature, a fuel cooler which is cooled by the refrigerant of the air conditioning system is fitted in the engine compartment." That is really all they say
  9. Yes, they should as long as the 996 is a coupe.
  10. :welcome: Are you sure all of the cluster plugs are "locked" in place?
  11. More likely your gas cap. Check the o-ring on the gas cap.
  12. Find a good shop with a PST2 or PIWIS tester and have them run the Tipronic diagnostics.
  13. Each wheel bearing has an MSRP of about $80 - so I assume the $500 is for both.
  14. sorry coupe thanks Lorren! Also interested - assuming I can use the same on my '01 Boxster..... Boxster will be different still - the main difference between coupe and cab is the length (due to mounting points) so the Boxster is likely different.
  15. sorry coupe thanks Lorren! Hmm... PET does not show any colored seat belts for pre MY02 cars. The seat belts changed in MY02 and have pyrotechnic charges in them (like air bags). I do not know if you can safely put a MY02 seat belt in an older car. You might email or call Jeff Clark at Sunset Imports (Porsche Parts at Dealer Cost) and see what they about using the newer belts in older cars.
  16. Coupe or Cab? (they are different)
  17. Try 9663 or 9661
  18. 987 version 986 version
  19. You've got to be kidding - pulling the plugs on a turbo is a 3 hour job. It would be in his best interest to have the OBD II codes scanned before he touches anything (as wross996TT said).
  20. Can you give us the fault code numbers?
  21. Does it matter that My car is a 2002? Gary Porsche does not recommend anything over 18" for 996's period. The 997 has a stiffer chassis so 19" wheels are okay there.
  22. On the right side of any forum is a link called "Search". Click on that and type "+cluster +remove" (without the quotes)
  23. 997 and Cayenne seal is the same seal. I personally would borrow the right tool. Folks that have used the tool and new seal seldom have an RMS problem again.
  24. Cayenne (V6) gets 17" rotors Cayenne S and Turbo gets 18" rotors Cayenne Turbo with HP brake kit gets 19" rotors
  25. The electrical parts between a 987 and 997 are almost identical.
