  1. It is always helpful if you give us the exact model and year of your car.
  2. You likely need to look at event history under the alarm section for the latest faults.
  3. 997.613.261.00 01C has been replaced by 997 613 X 01C and is only available as an exchange part.
  4. Hmm.... didn't read the Lost Radio Code FAQ. "CDR-23 (or later): These radios do not have a security code - that is, not that the user enters. These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  5. You will need a Porsche specific scanner to read the alarm fault code(s) and find out what is failing. Some alarm issues can be easily fixed by DIYers.
  6. P12A1 Possible fault causes Predelivery quantity or pressure in fuel low-pressure circuit too low Fuel high-pressure system leaking Fuel high-pressure sensor faulty Fuel high-pressure pump faulty P1026 Possible fault causes Only if the value is below the lower limit: Predelivery quantity or pressure in fuel low-pressure circuit too low Tank (almost) (driven) empty If the value is below or exceeds the limits: Quantity control valve faulty (in fuel high-pressure pump) Fuel high-pressure pump faulty
  7. Did you send him a PM?
  8. TSB Lstings (only) only are here: https://www.renntech.org/partsfinder/ Sorry, no Porsche copyrighted materials are allowed on this site.
  9. Plead read the Lost Radio Code FAQ and follow the procedure there.
