  1. Top right of any page Glossary. PHC - Porsche Hill Control. The hill-holder function on Tiptronic S (or Porsche Drive-Off Assistant on vehicles with manual transmission) allows the driver to stop on a hill and drive off again without having to operate the brakes. It also enables a steady slow descent down steep slopes or icy mountain roads at speeds of up to 20 km/h (12.5 mph) using engine braking. This is provided by the engine drag-torque control (EDTC) system, which prevents wheel lock-up on overrun or following downshifts on low-grip surfaces. Selective braking is applied to individual wheels resulting in a considerable increase in steering precision.
  2. Model and year of your car please?
  3. I would try 5W-50 or 15W-50 and see if it makes any difference.
  4. 996.551.019.28.A03 Lining in black (no memory options) -- US MSRP $231.84
  5. Hmm... may have to get our lawyer on that.... :lol:
  6. Nick is correct. Interesting that GT3RS shift knob (with deviating stitching) has an MSRP $50 less. Go figure...
  7. If you use CRC the red can is chlorinated and the green can is non-chlorinated.
  8. That number is for the retaining frame for a Tiptronic shifter. I will need to know your interior color to get you the correct part number (matching leather).
  9. Lost Radio Code - FAQ PLEASE READ THIS FIRST
  10. http://www.renntech.org/forums/index.php?s...ost&p=86705
  11. P0420 TWC Conversion, Bank 1 – Above Limit Potential causes: – Catalytic converter P1275 Signal Delay Time for Oxygen Sensor Aging, Bank 1 – Above/Below Limit – Oxygen sensor ahead of TWC – Leak ahead of TWC or in the area of the oxygen sensor after TWC – Wiring (oxygen sensors exchanged) The only tricks to changing the O2 sensors are having the right tool (slotted 19 mm socket) and NOT using any sort of penetrating oil etc. anywhere near the sensors.
  12. Start by checking for loose swaybar mounts. If those are tight then look at the upper strut mounts - look for signs that they are moving in their slotted holes.
  13. Loren, Thank you! I disassembled my mirror last night and it does appear that I need to replace part #5 on the diagram only. the part number listed in my mirror was 996-731-219-04 and that is listed on the sheet you attached. There are a lot of other #5 part numbers listed, do I need to order all of them or just the one. The car is a 2004 BoxS without the auto dimming mirrors. You need to check your options list and see if you have option 266 (self-dimming) or option 537 (seat memory). Then order by year and options. Jeff Clark at Sunset Imports (Porsche Parts at Dealer Cost) can help make sure you get the right part (and at a discount).
  14. http://www.beckerautosound.com/
  15. A C4S already has larger radiators (and ducting) than a narrow body car. I think if you want to do this on a widebody car you might do better with the Turbo radiator and hoses.
  16. P0301 Misfiring, Cylinder 1 Check for a bad coil pack. poor electrical connection or even a bad spark plug. On a Boxster cylinder 1 is right side - cylinder closest to the front of the car (on that side).
  17. Sounds like a small vacuum cleaner - will only run for 2 minutes or so.
  18. Please read the FAQ - and follow the instructions. Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  19. Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  20. Thanks again. I had a 80,000 km done when I bought the car in March. Where is the air pump located? Does it run at startup? If not, start by checking the fuse. It is a 40A fuse on relay support 2 - which is next to the DME. Sorry, I don't have a picture of the pump location. It is in the left rear under the intercooler upper hose. Perhaps someone with a TT can take a photo.
  21. You can't use your headlights with a TT/GT2 bumper or a MY02 or later GT3 bumper - without changing the front fenders also. The profile changed. You would also need some wiring changes for the new style headlights. Conversely an aerokit cup or RoW GT3 front bumper will be a bolt-on solution.
  22. The air pump runs usually only at startup - for emissions reasons. It may or may not cause a CEL because the pump only runs for a short time. Here is the US it would cause you to fail an emissions test. If you have recently had work done on the car check to see if they accidentally forgot to plug the air pump back in.
  23. 996TT, 09/2001 (MY02?) P0491 Secondary Air Injection System, Bank 1 - Insufficient Flow P0492 Secondary Air Injection System, Bank 2 - Insufficient Flow Possible cause of fault - Electrical fault in power supply or line between relay and secondary air injection pump - Secondary air injection pump relay mechanically faulty - Mechanical fault in electrical secondary air valve - Pneumatic secondary air valve faulty/sluggish - Electrical fault in secondary air injection pump - Mechanical fault in secondary air injection pump or secondary air injection pump blocked - Vacuum system leaking - Air hose to secondary air injection pump slipped off or constricted
