  1. According to the parts list there is one center console.
  2. Have a look at this...
  3. What is the exact model and year of the car, please?
  4. There are no image limits for Contributing Members.
  5. Change the brake fluid and check the pads and discs. Change the fuel filter (up under the car on the C2). Of course, check the battery with a hydrometer for each cell (unless it is an AGM battery). Also check charge and charging voltage (should over 13 VDC).
  6. Try 3450 PS. Porsche didn't do it Becker did.
  7. The front drains start in the area in front of the windshield (where the battery is) and exit in the wheel well housing. The HVAC drain starts in the cars interior connection at the condenser and exist directly under the car. The sunroof drains begin in the sunroof channel and exit in the wheel wells.
  8. U0155 Instrument cluster, communication Possible fault causes - No power supply for instrument cluster - Instrument cluster incorrectly coded - Short circuit or open circuit in the CAN display - Instrument cluster faulty (in most cases the cause is not the instrument cluster but incorrect coding!) U0146 Gateway control unit communication Possible fault causes - No power supply for Gateway control unit - Incorrect coding of Gateway control unit - Short circuit or open circuit of CAN Drive - Gateway control unit faulty (in most cases the cause is incorrect coding and not the Gateway control unit!) U0418 Stop light switch Possible fault causes - Open circuit in signal wire from stop test switch - Stop light switch faulty U0423 Fault entry in specified control module Possible fault causes - Control module is incorrectly coded - Periphery connected to specified control module is incorrect - Control module faulty (in most cases the cause is not the control module but incorrect coding!) 1990 Positive engine torque intervention not possible Possible fault causes - Fault in CAN bus - DME control unit detects engine fault
  9. Exact model and year of the car please?
  10. Did you read the Lost Radio Code FAQ?
  11. You will need to find a salvage yard for internal light parts as Porsche only sells the whole assembly.
  12. Reverse the battery - press the button once. Replace the battery in the correct orientation and try again. If that does not fix it then you likely need a new key fob (and the $150 programming to your car).
  13. The diagnosis detects pulsations in the intake air tract from the boost pressure sensor reading. When the overrun recirculating air valve is stuck in closed position, these are produced by the exhaust turbocharger (pumping in the direction of the closed throttle valve). This fault can also occur in extremely cold conditions when the membranes of the overrun recirculating air valves can be frozen solid for a short time just after you start the engine.
  14. P1666 Overrun Recirculating Air Valve - Signal Implausible Possible cause of fault - Overrun recirculating air valve stuck in closed position at times (due to ice) - Overrun recirculating air valve faulty
  15. Please read and follow the instructions in Lost Radio Code FAQ This topic is now closed.
