  1. Are you using a Porsche specific scanner to check for fault codes?
  2. If you get wheel spin this can sometimes happen. It basically resets itself afterwords.
  3. Fault code 1772 Pressure sensor signal wire Possible cause of fault - Short circuit to B+ in the wiring of pin 84 of the level control module - Short circuit to ground in the wiring of pin 84 of the level control module - Open circuit in the wiring of pin 84 of the level control module - Level control module receives implausible signal from pressure sensor - Pressure sensor faulty - Level control module faulty
  4. Porsche PET parts list - we have a paid subscription.
  5. Item 2 - 996 551 211 00 Front footrest -- US MSRP $16.01 Item 3 - 999 073 062 02 Panel Screw -- US MSRP $0.89 Item 4 - n/a Panel Nut (common consumable part) Item 5 - 996 551 611 00 Cover for footrest -- US MSRP $15.02 Item 6 - 999 919 161 09 Fillister head bolt -- US MSRP $1.00
  6. https://www.renntech.org/forums/applications/core/interface/file/attachment.php?id=37501
  7. CDC-3 is the 6 disc cd-changer in the front trunk. Try 3231
  8. Put a Porsche specific code reader on the car (like PIWIS or Durametric) and report the fault code(s) here.
  9. The alarm microswitch for the center oddments tray cover.
  10. I have had good luck with Rejex; Amazon.com WWW.AMAZON.COM
