  1. Perhaps someone installed a new switch on the brake pedal?
  2. P0446 EVAP Canister Shutoff Valve (Function) - Below Lower Limit Potential caues: - Purge air line blocked. - Flow resistance of EVAP canister too high. So if the line not plugged then your canister may be bad.
  3. Egas on Carrera's was on MY99 C4 (MY99 C2 is the only non egas Carrera (996)
  4. There are some pics here of the installed part.
  5. P0134 Oxygen Sensor Ahead of TWC, Bank 1 – Interruption of Signal Potential causes: – Wiring harness – Oxygen sensor – DME control module Did you check the wiring harness? Was the right sensor changed?
  6. I already replied to you in your first thread. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST The FAQ has a link where to post these requests - PLEASE use it.
  7. :welcome: Please give our search a try - the article you are requesting is pinned at the top of this forum. Cruise control
  8. Try 7113 ot 7111 Numbers didn't work I did 7115 also.... Did you read the FAQ -- I think not.
  9. Have someone push down on the front edge of the hood while you press the release button. Could be a jammed latch.
  10. You need to read and follow the instructions - I will ONLY answer Lost Radio Code request in the one Lost Radio Code thread. The link is in the FAQ. Go to Lost Radio Code - post your request here and post your request at the end of that thread.
  11. 996.522.321.01.01C Actuating lever (left) -- US MSRP $1.20
  12. Yes, the car sill start, idle fine and run pretty well up to 4000 RPM with no MAF.
  13. Then there should be no over-revs period in the break in period. One spin at the track can void your warranty. A 997-1 DME records the following rev ranges: Range 1: 7300-7500 RPM Range 2: 7500-7700 RPM Range 3: 7700-7900 RPM Range 4: 7900-8400 RPM Range 5: 8400-9500 RPM Range 6: 9500-11000 RPM
  14. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  15. 2nd time I have posted this... you need to follow the instructions. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  16. Follow the Owners Manual - and you can not be denied a warranty claim.
  17. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  18. Your dealer will need to know if you have option M220 (Limited Slip Differential) and your VIN to get the correct cable (they changed mid year). They run about $315 US Retail.
  19. Please do a search here - switch removal has been covered many many many times here before.
