  1. What specifically do you need?
  2. :welcome: Model number on your radio please? (i.e CDR-220, CR-220, etc.) Also, BOSE (M680) or Harman (M490) amp?
  3. It is here listed under Literature and Other TSBs. Purchasing VIN Plates, Certification Labels, and Emissions Labels, 987/997 Tire Pressure Labels Link only works for Contributing Members.
  4. Try 5681 or 5679 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  5. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  6. This was already answered in your first post - please do not double post.
  7. Buy a hand pump from your local auto parts store.
  8. Start by checking the clutch switch (bypass it).
  9. It is not the PIWIS - it is the DME that will not allow you to change those items. If you have a new DME you can program it to the old DME settings - but (for legal reasons I am sure) you can not re-program certain settings in an old DME.
  10. I already posted the 996TT diagram for you here. And, the 997TT diagram. Please make up your mind what you want/need. Loren, Yes thank you for the other diagrams. I actually need the tail lights ones. 997-2 tail lights
  11. If you had a coil pack problem you would have misfires and a a CEL. Time to look more closely at the possibility of air leaks.
  12. I already ran the number for you in the Lost Radio Code thread. This thread is now closed.
  13. Try 0637 or 0635 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  14. If you search the press releases on Porsche's website some of that info may be there.
  15. OPC = Official Porsche Center or your local dealer.
  16. OBC and cruise is 996.613.219.10.EWC OBC only is 996.613.215.10.EWC On either one you will need to move the caps (with the printing on them) from the old stalk to the new one. OK, thanks! Since I have the computer (and therefore 4 stalks), I will need the 219, correct? Yes.
  17. Per Peter Smith... Boxster 986, R1, 7200-7800, R2, 7800 and up 996, R1, 7300-7900, R2 7900 up 996TT, R1, 6750-7250, R2 7250 up 996 GT3, R1, 8200-8800, R2 8800 up Carrera GT, R1 8400-9000, R2 9000 up 987 Boxster, R1, 7200-7500, R2, 7500-7700, R3, 7700-7900, R4, 7900-8400, R5, 8400-9500, R6, 9500 up 997 Carrera, R1, 7300-7500, R2, 7500-7700, R3, 7700-7900, R4, 7900-8400, R5, 8400-9500, R6, 9500 up 997 GT3, R1 9000-9200, R2, 9200-9400, R3, 9400-9600, R4, 9600-10000, R5, 10000-11000, R6, 11000 up 997TT, R1, 6800-7000, R2, 7000-7200, R3, 7200-7400, R4, 7400-7900, R5, 7900-9000, R6, 9000 up
  18. I already posted the 996TT diagram for you here. And, the 997TT diagram. Please make up your mind what you want/need.
  19. 1. Pretty much yes. 2. Yes. 3. Yes if you open any lines or remove the calipers completely. No if you are just changing pads. Yes, just carefully hang them to side.
  20. OBC and cruise is 996.613.219.10.EWC OBC only is 996.613.215.10.EWC On either one you will need to move the caps (with the printing on them) from the old stalk to the new one.
  21. 1. Pretty much yes. 2. Yes. 3. Yes if you open any lines or remove the calipers completely. No if you are just changing pads.
  22. Try 8448 or 8446 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  23. Try 4920 or 4918 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST tried bith keys but i have a wait message on screen i know you have to wiat for 1 hour. but what happens affter that does the radio work or is it a lock out to try again after 1 hour thanks READ THE FAQ!
  24. You should be fine with most major brand tires.
