  1. Try 4898 or 4696 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  2. Good grief you are not asking what me what I said 3 years ago are you? :) I sent you a PM.
  3. We have the latest TSBs here. When it says Superseded that means the one listed superseded a previous TSB.
  4. We have added and/or updated February 2009 TSBs in the following categories (9 TSBs total): 987-1 = 1 987-2 = 2 Cayenne = 1 Cayenne gen 2 = 3 Cayman-2 = 2 Of significant note is an oil capacity change for the MY08 an MY09 Cayenne V8 engines. Dealers/OPCs are to update Owner's Manuals with a supplementary sheet that has the following changes:
  5. Read the fault code(s) and write them down. Yes, the Durametric software can reset the air bag light.
  6. Where you are pointing to could be a leak in the windshield washer tank and/or headlight washers (if you have them). Both tanks are located there behind the wheel well liner (high in the fender).
  7. :welcome: If you can not find one on eBay you can still special order a one. The current Porsche parts/price list shows: WKD 911 020 86 Owners Manual (English) -- US MSRP $46.48
  8. You do not need to replace any coil packs that are not cracked or pass the resistance test. A good coil should read: Resistance between terminal 1 and terminal 15 at 20°C: 0.3 - 0.7 ohms Obviously a higher (or lower) resistance is a bad coil. The (current) correct coil pack for your car is: 997.602.107.00
  9. Your misfires are only on cylinders 1 and 4. I would line up the TB arrows anyway but check the coil packs and plug connections.
  10. Try 7001 or 6999 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  11. P0030 H02S Heater Control Circuit Possible cause of fault - Open circuit P0134 02 Sensor Circuit No Activity Detected Possible cause of fault - Short circuit in oxygen sensor wiring - Oxygen sensor faulty (heater coupling or heating) - DME control module faulty You could erase the faults and see if they come back.
  12. From the service manual it looks like - "initial tightening 37 ftlb." then final tightening "an additional 90 degree turn."
  13. Try 4715 or 4713 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  14. Very unusual - good troubleshooting!
  15. Try 1030 or 1028 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  16. Try 3441 or 3439 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  17. I need your radio serial number. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Thanks for responding Becker 1 4462 48/98 X5020732 Thank You. :) Try 2513 or 2511 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Thank You, :D Please tell me how much i owe you, Thank You, I appreciate it. -What other types of Codes are You able to get, such a key programming, or specifications such as how to program a key remote alram, Thank You :) I entered the 1st number, it went back to code. i entered the 2nd number, but i think the last number wasnt pressed correctly and it went back on code. The third time i re-enterd 2511 and the "WAIT" message is displayed, any Ideas Thank You!! :huh: READ the FAQ.
  18. I need your radio serial number. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Thanks for responding Becker 1 4462 48/98 X5020732 Thank You. :) Try 2513 or 2511 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Thank You, :D Please tell me how much i owe you, Thank You, I appreciate it. -What other types of Codes are You able to get, such a key programming, or specifications such as how to program a key remote alram, Thank You :) Key program codes (IPAS codes) must be obtained from an Authorized Porsche dealer/OPC. Then you need to protect hem because anyone in possession of those codes could program a key and steal your car.
  19. Maybe an OPC parts guy can request those part numbers from Porsche - they do not show on the Porsche parts list (only the complete kit shows).
  20. If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  21. I would wait for the power bleeder and try again. Could be a clog or debris in the (booster) block where the reservoir connects.
  22. Most likely a seat belt buckle. See the TSB on this. You will need the Durametric Software, a PST2 or PIWIS tester to read the fault code(s) and rest the airbag light (once the fault is corrected).
  23. I need your radio serial number. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Thanks for responding Becker 1 4462 48/98 X5020732 Thank You. :) Try 2513 or 2511 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  24. Get a Motive power bleeder - a very worthwhile investment (IMHO). Pumping the brake pedal still allows for air to be sucked back into the system.
